Medic's Demon
Re: Medic's Demon
jeaton01 wrote:Looking good, Mike.
Thanks!
Re: Medic's Demon
The second wing half is attached now. This one will need some putty at the wing roots as well.
Re: Medic's Demon
That's looking great Mike!
Re: Medic's Demon
Thanks Stuart!
Re: Medic's Demon
I was going to fit the rudder but the fit is bad, especially at the top. I added a piece of strip styrene that I'll trim to the rudder. Please ignore the mess on the rudder. That'll be cleaned up later.
Re: Medic's Demon
Added the PE to the outside of the airbrakes. The PE is pretty thick, so this will be glued in stages.
Re: Medic's Demon
Started on the gear as well. Wheels are being painted and the gear legs assembled. I dry fitted the gear legs to check and see if I got both wings at the correct angle. Yep! Good to go!
Re: Medic's Demon
Looking very good! Gear looks great.
Re: Medic's Demon
Thank you sir!
Re: Medic's Demon
Yeah... Good fit on that rudder... not!
Great work thus far Mike!
Return to “Jet GB by Portman”
