Very nice!
Heinkel He 100: Intercontinental Friendship Model Shop Pt.1
Re: Heinkel He 100: Intercontinental Friendship Model Shop P
Thank you so much, Carlos! I truly appreciate your support. Truly. I think this is close. Here is a decent enough (I know it’s in motion but it’s quite crisp) side view:
Here is my overlay:
I think this has just enough of the curvature to match the original form. The MPM kit does not do this shape well either so it would be necessary in either case to build the cowling up correctly. I did sculpting, very gently, because once the Milliput is gone I would have to add more. So I am good. I am also quite close to the original intention of how to do these fuselage changes:
Here is my overlay:
- jeaton01
Looks good, Bruce.
Thanks so much for your comments, John. Sincerely!
Your correction work has really paid off! It looks so much closer now.
Good nose job Bruce!
Looks to me that you nailed that shape perfectly! Way to go Bruce!
Thank you, Clint.Floki wrote:Your correction work has really paid off! It looks so much closer now.
Thank you, Kari. Looking forward to catching your latest projects. Same goes for everyone here.
Thank you, John.keavdog wrote:Very cool!
Thank you, Stuart. Haha. Yes, an improvement.Stuart wrote:Good nose job Bruce!
Thank you, Duke. Close enough.Duke Maddog wrote:Looks to me that you nailed that shape perfectly! Way to go Bruce!
The next steps will be to remove the area at the back of the cockpit, in order to fabricate a new clear part, then prepare the fuselage halves for scribing, and selective rivet work. The engine and wing mounts feature “Butter” (going off memory here so correct me if I am wrong) explosive rivets. Those do show up at a distance. Note to fabricate a coving cover for the gunsight, which I bet was designed to absorb light and make targeting easier, and a gunsight.
I am also going to try the Aqueous primer and colors to see what mischief and merriment is possible. Here’s a video of a comparison. Remember there is no spoon.
