Sum Bitch 2nd Class -4
Re: Sum Bitch 2nd Class -4
Look very good, I like the the paint work. That is a lot of stencils! I am with you….I rarely apply all the stencils.
She's heading towards the finish line later tonight. Not much left to do. Already installed the dive flaps, turtleneck canopy, bomb doors, dispenser rack with bombs attached, & rear gunner seat w/MG.
All is left are the canopy parts, mast antenna, and Yagi underling antennas. Flat clearcoat will be applied before canopy parts are installed.
- jeaton01
Well, the quantity of my Navy jets sure sucks compared to yours, John. The quality looks good too.
And your Beast is looking good, Tom, pretty soon you should be launching it (in a good way!)
Another part went to the black hole. The life raft container that goes to the rear canopy went click, click, click and gone. Had to remove e it from the canopy because I had it glued on the wrong side of the canopy. I pulled it off and set it aside. When I glued the cano oy to the fuselage and was ready to reglue it to the correct end of the canopy, it disappeared. Saw the direction it went and now I can't find the damn thing.
How hard could it be to find a small barrel-like object painted in green Zinc Chromate with a red handle painted ???
That's the last thing to do before calling it done.
- jeaton01
It's all my fault Tom I shouldn't have said launch!
If I can't find it, I'll omit it.since it's gonna be hanging from ceiling near my bench. I won't see it so it don't matter at this point. But.... in the back.of my mind I'll know it's missing.
Resumed the search and found it - under the leg of my bench. It must've bounced back under my bench. Not where I expected it find it.
Tried to re-install it but it's a no-go. Too tight of a fit next to radio.equipment as shown in instruction guide....
I can now rest easy knowing I tried and accept that it will not fit. Out of sight, out of mind is my motto for this situation.
She is finally done once the rear canooy is glued on. The next step is figure the best way to hang it using fishing line on which points....
