That's going to be a lot of sanding
Ask Lyle... gotta call the right man for the job. He's got lotsa tools for you to borrow.
- Modelcrazy
- Addicted Member
OK, got 'er done. I've painted a black prime to check if anything still needs work. I looked pretty good when I put it down for the night but will check tonight. I'll wet sand it down to a nice finish before re-scribing. The nice thing about the Sunderland is it was plated like a ship, so the lines shouldn't be too difficult to reproduce.
Looking good!
- Modelcrazy
- Addicted Member
Thanks guys.
I wet sanded with 2000 grit until all the seams were smooth. Next I need to rescribe and move on the the next steps. The canopy may pose an issue in fit as well. The scratches are also smooth.
- Ceaser_Sa1ad
- Master Member
Looks great!
- Modelcrazy
- Addicted Member
Thanks guys. I worked on the panel lines over the weekend. but had to go back over a few areas. It will take a few night working on the fuse to get it where I want it.
The Takao has a small area of marring on the deck after I attached the deck to the hull. Some glue got under the tape I was using and destroyed the hatch pattern on the deck. Not sure how to remedy this
. It's a small area that's under the front of the starboard catapult. I may end up putting a tarp draped over the catapult or something. My original thought was to portray her at the second battle of Guadalcanal but there wouldn't have been anything like that during a battle. So I decided to just have her steaming at cruise speed. One idea is just to sand off the detail and add some PE deck (if someone makes it), or nothing at all. Still considering and thinking about it as I go.
- Modelcrazy
- Addicted Member
I completed the 02 and flight deck, added doors and ladders and filled the gaps. I also started the addition of the gauss cable. Aoshima gives you a rubber tree for these cables and you install them in pieces
I started installing them using CA. also here is a close up of the damaged deck
- Modelcrazy
- Addicted Member
The Sunderland is becoming quite the bugger. I ordered some scribing tape to help me keep the panel lines straight.
On the Takao. I completed the gauss cable and mover to the funnels. While very detailed you know I just couldn't leave well enough alone so I ground out the plastic funnel caps, sanded the the hand holds, seams, everything and will replace them with PE an scratched bands. I also installed straws for tubing in the funnels. Were they there in the actual Takao? probably not, but they add interest I feel.
Now I need to check the seams and add everything back
splendid work. coming along quite nicely.
