Tack Bruce!
AND, back to the build with a brief update.
The last couple of days has not been too productive as I had hoped for. Some work with details, such as landing gear, tyres etc.
I skipped the idea to scratchbuild brake lines due to the idea to have a out of the box build.. Which of course will not
really be the case due to the AM belts I ordered.. But ja, I am fine with these twins..
However most of the time has been dry fitting back and forth the wings, nacelles, bays, engines etc. pretty complex construction.
First fit with a fully build engine caused this sort of gap issues, just does not fit inside the nacelle.
So, I took the other engine, that was just semi-assembled, lacking pretty many details and did the same dry fit test:
Looking pretty good and the fit in general is excellent (despite the engine hassle). As none of the engines will be visible in the finished build, I can quite easily make sure that they fill fit perfectly inside the nacelles.
Let's see what next!
