Fishing season has started so I've not been as hyper-focused on modeling as I have been. Jumped back onto the D-9 build for a few updates. The tail stabilizers have been riveted.
The cowling flap actuating rods were added from the Eduard Exterior set.
The rear engine assembly has been giving me the most pause, as usual. You'd think that after building this kit for the fifth time, that I'd have some sort of system or at least good idea of how to approach this area but I took a slightly different approach this time. Guided by photos of the Jumo 213 engine, I added some wire junctions on either side of the engine body instead of just spreading random wires around the periphery of the visible engine as I've done in the past. I'll still add the peripheral wiring but I thought working from the inside out might get me a more realistically cluttered look to this area.
Here are the majority of the engine components ready for painting.
The components with metal wiring are primed with Mr Primer Surfacer 1000 first.
More engine work to come!
Your work is such a joy to see and follow? Beautifully done.
Beautiful work! The best of luck to you this fishing season
You and these D-9's of yours......you are ALL over it man!! The detail.....the DETAIL!!! I learn a tremendous amount of not only modeling skills but about this airframe in general every time you build one.
mustang1989 wrote:You and these D-9's of yours......you are ALL over it man!! The detail.....the DETAIL!!! I learn a tremendous amount of not only modeling skills but about this airframe in general every time you build one.
:that:
Awesome work as ever John!
Back with another update on the D-9! I finally worked up enough motivation to finish the engine plug. After adding some wiring to the engine body itself, I drilled out some holes in both the forward and rear engine bulkheads for additional wiring runs and then painted the engine parts while the parts were still separated.
I then started gluing the engine components together and adding wiring along the way to further complicate/populate this area. The wiring work is not accurate but is intended to simply give the impression of complexity.
The ammo cannisters and chutes were chipped using hairspray to represent a bit of wear and tear in this area.
The last component of the engine plug to be attached is the rear bulkhead. I've added some yellow electrical wiring bundles.
The wheel well insert was also painted and chipped with hairspray.
Now that the engine plug has been completed, I can dry-fit it into the fuselage to see what it looks like with the wheel well insert in place.
Lots of this work gets hidden once the central wing part is in place but there is enough visible to make the previous work worthwhile.
:shoutout: More gorgeous work John!
Cool!
Wow...
