Matchbox 1/72 Saab J29 F Tunnan by speedgraflex
Re: Matchbox 1/72 Saab J29 F Tunnan by speedgraflex
Stikpusher wrote: ↑Sun Sep 13, 2026 9:32 pm
cbaltrin wrote: ↑Sun Sep 13, 2026 10:14 am Looking good Bruce! If I was building this I would design a faux intake plug buck and vac form it. Just enough depth to trick the casual observer and maybe an undersized engine front to sit at the end :hmm:
A very good idea… another option is to create the intake cover used on jets while parked on the flight line between flights. I did that on my last F-16 and my F-86. There is usually a similar plug or cover for the exhaust as well.
That's a good option to consider, Carlos! 👍 I did the same on my Monogram F-86F model. I cut a piece of Evergreen sheet to shape and covered the edge with wire insulation to replicate padding and added a pair of wire "handles" in the center. This isn't a great photo but you can get the gist of the idea, Bruce. :grin:
This link to some Alamy photos has some good ones of the Tunnan. The first is a straight view down the intake to the exhaust with the engine removed… you can see how straight line it actually was in this photo. The second photo has an intake plug fitted if you want to go that route.
https://www.alamy.com/stock-photo/saab- ... y=relevant
Great advice, gentlemen! Thank you so much. I appreciate all of these ideas. Some I have thought about but I didn’t know if I could or should (such as red plugs, which I’ve seen but I didn’t know that these were protective and I should have because Me 262’s had all of these issues) and vac forming.
I had to reconfigure my home to accommodate my landlord’s desires and I’ve been relocated for 7 days so I moved old stuff around and found this issue of Combat which has to belong to me. I forgot I had it. Not Tunnan but Horten related 80s goodness inside. Revell 1/72?
In addition here are some visual notations on what to do with the interior based on the Tarangus 1/72 kit.
The blue area I’m not changing but I needed to show it for ID purposes. I’m still not sure what the diagonal tubing does. Hydraulic assist for something? It seems possible that this was also modified a bit. I’ve seen variations on F air frames.
It looks like the aluminum frame has built in segments to hang various components off of it; I’m not sure what the large square plate does. I’ll add it at some point.
That sounds like a good idea. The Horten though doesn't look like the Revell kit in that pic; given that it came from a mag that is focused on Scratch and Vac models; I'd say it was a vac formed kit. The canopy doesn't look like anything produced by Revell. It does look good though!
The magazine is dated 1983! I do not think that anybody made a kit of the Horten in injection plastic back then. It was way too off the beaten path for the early 80’s. I’d say that your guesstimate of a vacuform kit is the most likely correct answer Mark.
Mark & Carlos,
You’re both right! What was I thinking??
I don’t have the magazine with me, but I looked up the details for the issue and this was Combat Models Horten 229, a vacuum kit in multiple scales including 1/32! I couldn’t find more details on Scalemates but I did see the kit listed on the LSP database (useful database, too).
Thank you so much for your comments!
Superb bit of work on that u/c bay Bruce - very nicely done :shoutout: :shoutout: :shoutout:
Thank you so much, Stuart! I’m excited to see where you will go on your vintage Meteor!!!!!
