Heres a smaller Kamov - Ka-15 Amodel 1/72
BsYamato
Post by BsYamato »
Lately i have too much helicopters on the workbench (last night finished a kiowa.. no wip here sorry :DH: ), so to oviate to this i .. sterted another one :quotes:
This time not an easy game, a short run helo from Amodel , fortunately i get some experience few years ago with the Ka-18 that have the same rotor sprue and the way to run is clear.
Out of this i have a second version of the 15 (agrarian use) and the 126 from amodel , but this will be another story :)
Box'n'sprues:
From the box he seems as polar missions use, the kit included four plates, i suppose as rough landing pad surface.
Part of original cockpit glued
Now not original
fuselages, one with air intakes opened but..
In mind to put from inside a tiny web to replicate metal grids but the plastic is too thick. Resolved with dremel action
about half millimeter removed from the whole engine zone and more
Another problem, little windows are wrong, so i put a rectangular housing for plastic strips and shaped them (also in the picture i opened an upper air intake that the kit missed
ready
on the rorors:
the basement, the middle plate with eight holes done , and the IP
the middle plate again on one of blade controllers
Bottom rotor, seeing referencies pictures he needed to put upside down and remove disc at the base and mane a new one opposite side
both rotors with blades on
It's a short run, the i saved time to clean the numerous command rods and i started to scratch them with stretched sprues (none of my ready plastic rods was with the correct diameter :( )
Top rotor
bottom rotor. More challenge, the two plates will be supported only by rods (to keep the rotors turning) .. so i helped the operations with the main shaft to glue them in place
the upper plate only with two rods and two rectangular commands on the third side
The complete rotor after a whole day :drum:
the original rotor
http://walkarounds.airforce.ru/avia/rus ... 15_086.jpg
Really tiny but good to see this accomplished :yahoo: .. now in the stash remains to build only a Ka-15, a Ka-126, two Ka-25, two Ka-27 and two Ka-28 :DH: :DH: :DH: and probably more to come :bored:
At the next!
Re: Heres a smaller Kamov - Ka-15 Amodel 1/72
it is so small but your work is excelent
:shoutout: looks like another beautiful project from you. I like the lighter against the sprues for comparison.
Nice looking little bird. Keep going, this is looking great!
midnightprowler
Post by midnightprowler »
This looks cool, and tiny.
1 Corinthians 15:51-54
1 Thessalonians 4:13-18
Ask me about Speedway Decals.
VanceCrozier
Post by VanceCrozier »
Looking good sir!!
Paul
Post by Paul »
You need a more steady hand at those little kits than I have. grand job.
BsYamato
Post by BsYamato »
Thanks :bow:
weekend works :
Glued tail surfaces , cleaned main wheel and front gears and primer with white . Rotor primed with humbrol 144 grey
More pieces on cockpit with stretched sprues and plastic sheets. Also started to modify seats
At the next :)
BsYamato
Post by BsYamato »
Last night update
More added details in the cockpit and glued the cockpit on the right fuselage (the two rods are for pedals, to cut at right lenght)
Front searchlight housing
putty filling, sanded ad added front details to the IP
At the next!
PS
feels like antother kamov soon on the table :whistle:
Nice. And tiny too! :shoutout:
