Posted: Tue May 31, 2022 7:10 pm
The serial numbers have been painted.
When I tried to place the "JJ" code, I found that is to large for the space that is between the serial number and fuselage roundel. The masks are traced from the decals so either the serial number or roundel is slightly out of position. Probably the roundel. But there is no way I am going to redo the roundel so I measured how much I'd have to squeeze the JJ down to make it fit. About 0.4mm.
These types of adjustments are super easy to make in AutoCAD. I wanted to keep the height and thickness of the letters intact so I simply cut out a 0.2mm section of the horizontal part of each "J" to get the 0.4mm reduction.
The JJ+F codes are painted in Sky, same as the tail band. For anyone using this type of vinyl mask, framing the mask with sections of paper like I've done make it MUCH easier to slide the mask into the correct position without the adhesive catching the model prematurely because of the vinyl bending.
The codes fresh after mask removal. I still need to rub down the raised edges. FYI... I used the original "JJ" on the port side so the JJ's are different from one side to the other but I don't think it will be noticeable. The only other painted marking left are the black walkways on the wing roots.
