The Revell 1/48 P-51D is a fine kit OOB. The cockpit was cutting edge when released, and still holds up well for its age. External detail is well done, and if you don’t mind raised panel lines, you’re in good shape.
To keep it simple and inexpensive for upgrades I’d make the following suggestions: if you’re not using the pilot figure, replace the kit seat with a resin AM seat that has the molded in harness such as those made by True Details, Quick Boost, or Ultracast; replace the IP with one by Yahu, Eduard Space, or some other 3-D company that are suddenly coming out with all sorts of similar goodies; lastly, if your don’t feel like hollowing out the machine gun bores, get ahold of some metal tubing such as made by Albion, and replace the molded in gun muzzles with matching size tubing.
Why sink many times the cost of the kit into AM accessories? Keep it simple and have fun.
Revell P-51 Mustang Aftermarket parts
Re: Revell P-51 Mustang Aftermarket parts
- Ceaser_Sa1ad
- Master Member
Sooo canopy glue?Gary Brantley wrote:Actually Johnny, Quinta suggests CVA glue, as well. I thinned some Evergreen Canopy Cement and used that to attach the IP on my Bf-109E-7. I imagine some good old Elmers would work as well.tempestjohnny wrote: They are on backing paper just like decals. But to attach them to the model CA needs to be used
- tempestjohnny
yup just looked it up.Ceaser_Sa1ad wrote: Sooo canopy glue?
Quinta Studios DOES sell a set of 3D Decals for the 1/48 P-51D but it is apparently designed for the Eduard kit. So no idea if it would fit the older Revell kit. But pretty affordable ($9 at Sprue Brothers)
As mentioned by others, I used Quinta Studios 3D decals on my F-14A build and was very impressed by this new product. I would describe them as highly detailed soft vinyl parts that are packaged on decal paper. You remove them from the backing paper with water like a decal but afterwards, you just treat them like a hard part and attach them with glue. I used card glue which is similar to Elmers White Glue. Because they are a soft vinyl material, they are flexible and also easy to cut, which would make it easier to adjust them to fit.
Red Fox Studios and Eduard are two other companies (there may be more by now) that also sell similar products.
For $9 you can’t go wrong…a gorgeous IP, seat harness, sidewalls, plus other fiddle bits…. That’s a good deal.
- Ceaser_Sa1ad
- Master Member
I must agree. I think when the time comes, that's the way I am going.
Thanks all
Thanks all
I really want to try them
