Page 1 of 2
Decal setting solutions
Posted: Tue Mar 08, 2022 6:50 pm
by BlackSheep214
I'm getting low on both Micro Set and Micro Sol and I love both products. Now I'm curious about AK Interactive Decal Adapter Solution. Has anyone used this product? I have been debating on getting this in place of Micro Set and Sol.
Re: Decal setting solutions
Posted: Wed Mar 09, 2022 7:02 am
by Medicman71
Never tried that one. I have, like you, use the Micro Sol/Set. I have Ammo's Decal Set/Fix and it's ok. Not as good as the Micro stuff.
Posted: Wed Mar 09, 2022 8:44 am
by keavdog
I'm too scared to change. The old Micro stuff has been working for 30 years
Posted: Wed Mar 09, 2022 8:48 pm
by Floki
Same, I've only used micro set/sol I've never had any major problems with it.
Posted: Wed Mar 09, 2022 10:50 pm
by Stikpusher
I used the square bottle Testors decal set ages ago, but don’t remember anything good or bad about it. My current alternative when Micro Sol & Set is not right for the job is Walthers Solvaset. That stuff works great, but must be used sparingly.
Posted: Thu Mar 10, 2022 7:09 am
by Tojo72
I have not tried that stuff but I use Solvaset,and I still have bottles of Micro Set and Sol,really haven't seen say need to switch.
Posted: Thu Mar 10, 2022 8:51 am
by Gary Brantley
Stikpusher wrote:I used the square bottle Testors decal set ages ago, but don’t remember anything good or bad about it. My current alternative when Micro Sol & Set is not right for the job is Walthers Solvaset. That stuff works great, but must be used sparingly.
Carlos, that just about describes my experiences too. I
still use the square bottle Testors and find the Micro Sol to be a bit hotter while Solvaset is what I use on the really stubborn decals. And speaking of decals, I learned that white vinegar will remove decals that are fully set and finished. It takes a bit of patience to get it off
and this effort was over enamel; acrylic paint might not stand up to the scrubbing/rubbing. Ymmv.
Posted: Thu Mar 10, 2022 2:40 pm
by BlackSheep214
Hmm... I'll restock on Micro Set & Sol since AK Interactive Decal Adapter Solution is $10 for a single bottle. Cheaper buying the Set and Sol instead.
Posted: Thu Mar 10, 2022 5:07 pm
by KSaarni
If only Microset and -sol would come, not only with built-in brushes in the cap but more stable bottles, then I would probably start using them again.
I simply don't like the unpractical bottle (I guess most of us know why
) and then the need of a separate brush.
Therefore I use decal setting solution Tamiyas Mark Fit (both strenghts) and Mr Mark, with built-in brushes.
I'm very satisfied with Tamiyas decal setting solutions
Posted: Fri Mar 11, 2022 5:49 pm
by BlackSheep214
Just watched a YouTube video reviews on different decal solutions. Only two got failed results (aside from the homemade batch of white vinegar and water) - AK Interactive Decal Adapter Solution and the little square bottle Testors decal setting solution.
Tamiya Mark Fit Softener and Mark Fit (Strong) and Mr. Mark Setter / Softer had high praises.
The video...
https://m.youtube.com/watch?v=_ZT2fwusQU8
