Zoukei Mura 1/32 Bf 109G-14 /U4 UnBoxing
Hey guys! I thought I'd share some pics of the latest USPS delivery. It is the newest release by Zoukei Mura... the 1/32 scale Bf 109G-14 /U4. This is not a review but simply a tour of the box contents with some minor commentary from me. I won't know anything definitive about how the model actually builds until I start building it and this one probably won't start for quite some time. I'm not going to delve too much into the variant that Z-M chose to depict but it makes sense on certain levels, primarily being its close relation to the much more common G-6.
The model was ordered from Sprue Brothers as soon as I found it was in-stock and ready for delivery. As usual, Sprue Brothers delivered it quickly and safety, double boxed with scrunched paper packing material.
The first thing that I noticed when I opened the box was the color of the plastic: grey! Which is a win-win for me. My last experience with a Z-M kit was the Ta-152H-1, which was molded in black and metallic grey... both of which I hated working with. Neutral grey is much easier on the eyes and I applaud Z-M for going back to the basics with this color choice.
The small black container has a nice resin figure of the Blonde Knight, Erich Hartmann, cast by Master Box of Ukraine. It's pretty cool to see this type of collaboration.
I'm not a figure builder but the figure seems to be well done.
The actual model is comprised of 10 grey and 2 clear plastic frets, each individually packaged in plastic bag. This is probably a necessity with a kit like this due to the amount of very fine and easily breakable parts.
Sprue A holds the fuselage parts. Or at least the largest of the fuselage parts, which extends from the cockpit to the tail. As you know, Z-M's schtick is to provide a significant amount of internal detail including bulkheads and spars, even though they will not be seen after assembly. Model assembly is patterned after actual aircraft assembly and this can result in some sacrifices in ease of model construction. So the major components, fuselage and wings, will cobbled together using a modular approach.
Finish of the plastic is satin smooth and Z-M utilizes what I call the "Hasegawa" approach to external detail by providing finely recessed panel lines but leaving the rivets off. I personally like this approach and gives modelers a choice by allowing those inclined to add something extra to the model if so desired.
Molding looks nice and crisp.
The older "short" rudder is provided on this fret but is not the only choice. One of many options that is included in this kit, increasing the value and appeal of this release.
More options: The short tail wheel comes in booted and unbooted versions.
Some interesting interior side detailing on the bigger Sprue A parts.
Sprue seems to contain the wing parts although I don't see anything that resembles a standard one-piece wing bottom. More of that modular approach it seems. All control surfaces, such as flaps, ailerons and leading edge slats, are separate.
Only the smaller kidney-bean wheel bulges are provided on this kit. Again, molding is nice and crisp and unusually smooth due to the lack of rivets.
The interior side of the wing tops house some raised detail for the wheel wells.
To be continued...
Re: Zoukei Mura 1/32 Bf 109G-14 /U4 UnBoxing
Moving on to Sprue C... which appears to hold the internal components of the wing structure. This is where the Z-M kits really get interesting. On one hand, the amount of detail, especially stuff that you've never encountered before in any other 109 build can be very interesting and even educational. But the whole tree falling in an unpopulated forest argument arises... what good is this detail if it is going to get covered up with the solid wing panels? And no, I am not a fan of clear parts!!! Being unfamiliar with the internal wing structure, most of these parts are a mystery to me, which I don't think this is a bad thing... IF the parts go together well and don't adversely affect the fit of the external panels.
The four oblong holes signal the trough that accommodates the legs of the landing gear legs but I don't see an obvious attachment point for the landing gear. Slightly nervous about that.
There is no Sprue D... was this intentional so that Z-M could call this Sprue E for Engine? Naturally, the kit includes a representation of the Daimler-Benz DB605 engine that powered the G-14.
Subjectively, the molding on these parts seems to be sharper than what I remember on the Ta152H build.
The amount of fine piping and tubing provided in molded plastic is staggering. Getting through the engine build without snapping one or more of these parts is going to be a real challenge.
The exhaust pipes are individually slide-molded, allowing the tips to be hollow. And leave the molded seam in place... the real exhausts had a weld seam here.
The tall late rudder style is included on Sprue F.
The smooth style tire is unweighted and features a separate outer hub for easier painting.
Both styles of rudders are devoid of any stitching detail but feature some very subtle undulations to mimic the fabric-covered surface.
Ahhh... and it looks like a late model tall tail strut is provided.
The majority of the cockpit components seem to be found on Sprue G.
An exception are the engine mounting arms.
The throttle quadrant features very delicate linkages and actuating rods.
This looks like the starboard sidewall for the cockpit with the oxygen regulator. The characteristic yellow fuel line is found the clear fret.
Sprue G also equals "guns". This looks like one of the MG131 guns that were mounted on top of the engine. (Correction: I think this is actually an MG151 20mm cannon and not an MG131. There is only one of these so I'm thinking it is an optional MG151 to be used in place of the MK108 that the U4 carried)
To be continued...
Looks like it’s gonna be a fun build for you. A nice score need! :shoutout: :shoutout: :shoutout:
ZM takes their interior detailing to a whole different level… wow! :wow: I can’t wait to see what you’re gonna do with this John?
The prop and spinner are the major components found on Sprue H.
The prop is one piece and features some nice hub detail.
The spinner has a nice row of rivets around the mid panel line and the correct trapezoidal openings for the prop blades.
The modular forward fuselage includes the narrow ring between the spinner and engine cowling and the bottom of the nose and chin intake. The small air scoops are molded open which is a very nice touch.
The landing gear legs look relatively simple with the oleo scissors molded in place. The attachment end looks... "different"... more nervous ensues as I'm trying to guess how these will be attached and when.
The brake lines, with the characteristic loop at the wheel end, are provided as very delicate-looking plastic parts.
Sprue I looks like mostly parts pertaining the MK108 30mm motor cannon.
Two styles of drop tank and an ETC rack are supplied on Sprue L.
The band that terminates in an attachment pin is actually a strap so completists might want to modify this area.
The final grey sprue (N) offers two versions of the gun cowling. The pair of MG131 machine guns mounted on top of the engine are also on this sprue.
Z-M offers two choices of instrument panels for the modeler. One of them is on Sprue N and features molded details on the instrument faces. I'm personally not a big fan of this approach since it's hard to align a decal precisely on these raised features and I also find it difficult to paint and finish realistically.
There are two clear sprues supplied with the kit. The bigger one, Sprue O, has the older two-piece canopy with the square frames and two styles of windscreen.
Here's the yellow fuel line part that goes on the starboard side of the cockpit wall.
The other option for the instrument panel is clear plastic version.
Sprue P has the late style Erla Haube canopy in two styles. I think that one is for retro-fitted G-6's and the other is for G models that had factory installed Erla Haube canopy.
That's it for the parts. Decals and instructions are next...
WOW :wow: That's a pretty amazing looking kit John!
Awwww MAN!!! You had to go and get this didn'tcha? I'll be tuning into this for damn sure.
Are they slated to make a 1/48 scale version of this one?
I'm curious about what that kit costs. Not that I'm going to buy one, but just to see what all that detail and choices sets one back. There is so much in that box! And like John, I wonder how many of those extremely delicate pieces would I break just removing from the sprue. That is one impressive model kit for sure! :grin: Get started soon brother John! :mrgreen:
mustang1989 wrote:Awwww MAN!!! You had to go and get this didn'tcha? I'll be tuning into this for damn sure.
As a fan of late war Luftwaffe fighter aircraft, a new tool Bf109G designed with the help of Radu Brinzan and incorporating new levels of interior detail was a no-brainer for me. I don't know if there are any plans for a 1/48 version.
Gary Brantley wrote:I'm curious about what that kit costs. Not that I'm going to buy one, but just to see what all that detail and choices sets one back. There is so much in that box! And like John, I wonder how many of those extremely delicate pieces would I break just removing from the sprue. That is one impressive model kit for sure! :grin: Get started soon brother John! :mrgreen:
$95 plus shipping from Sprue Brothers. My plan is to sit on this kit for a while. See some builds get done and determine if any aftermarket needs develop. Construction, especially the engine, looks to be very complex... not something that I want to jump into at the moment. But hey... you never know!
This particular boxing comes with markings for just one aircraft... Erich Hartmann's G-14/U4. Here is the decal sheet provided in the kit.
An acknowledgement to Mr. Radu Brinzan on the decal sheet. His involvement, not only on the decal sheet but in the overall design of this model kit, signifies Zoukei Mura's commitment to deliver an accurate rendition of the Bf109G-14/U4 into our eager hands! Decals are printed by Cartograph of Italy so no aftermarket decals will be necessary unless you want to model a different aircraft.
Interestingly, the decal sheet give you two sets of instruments for the IP, one grouped together in clusters and printed on a dark background and also individual instruments ala Airscale.
Zoukei Mura thoughtfully includes a set of canopy masks printed pre-cut on green vinyl but I would caution modelers on using these as I have seen these types of masks lift off of curved surfaces after application.
The instruction book is a 50+ page affair, which is a testament to the complexity of this kit. It is beautifully printed in full color and features not only line drawings but photos of the actual model parts to clarify construction. Careful reading is recommended prior to and during the build!
Color call-outs are of the numerical type and reference both Vallejo and Mr. Color paints.
A look at the two options for the instrument panel...
I was curious about the attachment of the landing gear legs and so I've highlighted the instructions. I've got a bit of concern over how small the glue attachment area appears to be. And also curious if it is possible to attach the legs out of sequence as it would be advantageous to not have the legs attached so early in the build.
And finally, here is the color profile of single markings option.
That concludes the unboxing of the new Zoukei Mura Bf 109G-14/U4 kit! It looks to be a very high quality and incredibly complex and detailed build.
Wow that's some detail. Can't wait to see you work your magic on this kit. I think that's a fair price given the scale and detail. Heck the 1/48 HobbyBoss Osprey goes for $125+
