Monogram 1/48 DC-3 - Eastern Air Lines
Posted: Tue Dec 09, 2014 11:26 am
I have about 7-8 of these. Either the DC-3 or the C-47. Love this airplane and this kit...(kit, well sort of.). Some great pics here:
http://www.primeportal.net/hangar/mikae ... 3_finnish/
and a lot of history, pictures, manuals, and assorted "stuff'' here:
http://www.douglasdc3.com/
I've spent hours at this site, just reading through all the material. Anyway, the little bitty Culver Cadet is waiting to be painted (trip to the store for paint) so I dug out one of these. Several things I'm trying: 1) wiring the engine, 2) adding brake lines, 3) larger size NMF and 4) decanting a chrome paint to use.
I did not worry about the interior as 97.3526 of it cannot be seen. Here is where I am so far.
The IP - was able to dab some Testor's clear plastic glue on the dials.
I was trying to make some controls for the throttle quadrant....could not get them small enough. But the process worked.
Interior...yawn.
OOOhhhhhh...detailing! I did paint the curtains white because I had the paint.
measured and cut tape for the windows and then closed it up. Gave a bit of a fight...
Here a gap, there a gap, every where a gap gap....
Wheels and engines started. Whees are Lifecolor Tire and Rubber Worn Rubber and the engine is Gunze Burnt Iron over flat black. The push rods are "chromed" by decanting a wee bit of the chrome and brushing it on.
Sprayed the props from the can. Promptly lost one (yes, it fell into a 45 gallon garbage can.....sheesh.) I robbed one from the stash kits as well as the tail wheel well cone. Sent Revell the kit info and asked for replacements. They said the kit was too old. I resubmitted using the latest C-47 kit number. I think they are sending them. Duh.
this is the first time I've ever dared to try to "wire" an engine. Using speaker wire. Not bad for the first time.
And finally, trying my hand at adding some brake lines. Using .45mm black beading wire.
That is where I'm at. Sure would appreciate any ideas, criticisms (helpful, of course) and such.
Thanks for looking.
Interior...yawn.
Thanks for looking.
