It has for the most part... but I have lots of scribing to do on the fuselage tomorrow.... I have nothing but time on my hands here...portman wrote:Looks like it cleaned up nicely Carlos!
1/48 A-7B VA-93
Re: 1/48 A-7B VA-93
Re: 1/48 A-7B VA-93
Today’s update.... keeping it simple
I glues the wings together... test fitting shows they’re gonna need a bit of seam clean up at the root mating surfaces to fit the fuselage with minimal seams
Then the stabilators were one part each... no gluing, but I had to sand off some ejector marks, and that removed some panel lines, so I rescribed them all...
Then I built up the kit bombs that I’m going to add... six Mk.82 500lb LDGP bombs... I’ll also add other weapons from a couple of Hasegawa sets to complete the load out, but they will come later...
so then Klaus had to inspect them for quality assurance...
Re: 1/48 A-7B VA-93
Seam clean up looks great!
Re: 1/48 A-7B VA-93
You'll have to get Klaus an inspection stamp!
Very nice work Stik!
Re: 1/48 A-7B VA-93
Too much handling, you’ll snap his tail off.
Re: 1/48 A-7B VA-93
Carlos and Klaus make a great team! Nice work, especially having to scribe those wings; not an easy task to do and you did so beautifully!
Re: 1/48 A-7B VA-93
Thank you all gentlemen...
Any progress is good!
keavdog wrote:Great progress.
I ended up wet sanding most of it... the Mr Surfacer was clogging my sanding sticks otherwiseFloki wrote:Seam clean up looks great!
I’m just watching out for his reject stinger...portman wrote:You'll have to get Klaus an inspection stamp!
I know... but I’m taking good care of him for nowBlackSheep214 wrote:Too much handling, you’ll snap his tail off.
Actually there were very few lines to rescribe on the stabs. Four on each surface and all straight... easy peasy!speedgraflex wrote:Carlos and Klaus make a great team! Nice work, especially having to scribe those wings; not an easy task to do and you did so beautifully!
Re: 1/48 A-7B VA-93
So after doing my bit of responsible citizenship yesterday, I did get in a couple of hours at the bench. I sanded the wing seams (and trailing edge thickness), rescribed lost detail on the fuselage seams... and then the big step... gluing on the wings
then a test fit of the stabilators.... those wont be glued on until after painting, just the ease on that a bit.
Starting to look like a SLUF now...
Re: 1/48 A-7B VA-93
Looking good!
