Italeri Viper kit with after Perfect putty applied and "wet sanded" down. Looks good, huh? Think I used sandpaper? Nope....Wanna know my little secret? Hot water and an old wash cloth. That's right. Perfect Putty is water based and easy to use and work with when completely dried. Work it out a little at a time with a wet wash cloth until you get this result....
Moving on to the Hobby Boss Viper kit...
Cockpit painted,decaled up, and glued to lower fuselage half...
Fuselage halves glued together....
I see very little filling work here. Should be easy peasy and painless.
Intake mouth part (3 pieces in all) minus the mouth piece
As you can see, more filling will be needed...
Perfect Putty applied and set aside to dry overnight...
