Thanks Carlos! That entire steering wheel was kit chrome. I'll probably dry brush some dark brown/ black ground up pastel on the steering wheel ring to make it look a little more realistic.Stikpusher wrote:The dash looks mighty fine! Is the steering wheel chrome plated, or did you do that with foil or by some other method?
Jo-Han Dyno Don Maverick-More Engine Detail-12/17
Re: Jo-Han Dyno Don Maverick-Dash-04/03
Re: Jo-Han Dyno Don Maverick-Updates-04/04
Got the mounts for the swing pedals mounted in last night so all I had to do this morning was adhere the pedals to the swing levers that I cut and formed last night as well and insert them into the drilled holes in the mounts. I'm good with this so......it'll be off to painting these and final mounting.
Re: Jo-Han Dyno Don Maverick-Swing Pedals-04/05
All your little improvements are starting to add up. Those pedals look much better!
Joe, just marvelous work. Outstanding!
Re: Jo-Han Dyno Don Maverick-Dash Complete-04/06
The improvement on those little pedals is ‘UUUUUGGGGE!
Miles past the OOB offering. Is the ProStock script a decal or did you freehand that?
Thanks Carlos and John.
John: That is an emblem / script from a Detail Master PE set. One of the liberties that I took with this car (and there aren't many on it).
