MiG-23ML Flogger G - Trumpeter 1/48
Re: MiG-23ML Flogger G - Trumpeter 1/48
Wow! That looks great!
- Norman
- Senior Member
Meanwhile in Hamburg, Germany ... Aires cockpit, feel my pain between my legs.
Instrument panel with small parts. Unfortunately, the instruments can hardly be recognized. Even though I painted it with white paint. Unfortunately too small to recognize anything. Next time I'll probably use a look part from Eduard
Testfit, not glued yet.
The Eduard Wheel wells are glued in with super glue and fixed with green stuff. My epoxy glue was to old for use. I hobe it will works. The fit of the parts was not so outstandig, which didn't make gluing easier.
Well done! What is the size of thus?
That's interesting... I got a different result using a similar Aires cockpit set. I sprayed the white onto the back of the clear acetate sheet. Maybe the ML cockpit instruments are different than the MF?
I love the crazy turquoise color in the cockpits of these Russian fighters. I wonder what the rationale was to use such a color.
I vaguely remember reading somewhere that the color was chosen for psychological reasons. The color is supposed to be visually soothing in some manner according to some Soviet scientific reasoning.jkim wrote: I love the crazy turquoise color in the cockpits of these Russian fighters. I wonder what the rationale was to use such a color.
Wow, that's a curvy and damn long mold line. But I'm sure you'll make it your bitch.
mostrich wrote:Wow, that's a curvy and damn long mold line. But I'm sure you'll make it your bitch.
Superb work!
- Norman
- Senior Member
It continued with the MiG-23.
The cockpit was glued into one half of the fuselage. I used the front wheel well with about 5 mm plastic spacer to place the cockpit a little better, for the further gluing.
For the HUD I cut some plastic in the upper area and lined it with a plastic sheet to align the HUD better later.
Afterwards it would have been better to glue the cockpit side parts to the fuselage halves without gluing the main cockpit part. A side wall had to be sanded lightly
Air intake parts from Eduard.
The splitter plates from the kit do not quite match the parts from Eduard, there is a gap. Due to the gap, the pins no longer fit to glue the air intake to the fuselage.
In addition, a lot of filling has to be done here, because you can see this area later.
Here you can see quite well that you have to completely fill the cockpit.
The MiG-23 will need a lot of filler
