The wire is a big (little) improvement!
Here are the wings that have been given a wash and the panel lines and rivets re-done where necessary.
Dry-fitting the wings and horizontal stabilizers to the fuselage... no issues spotted.
With the fuselage work being largely complete, it is time to glue the cockpit into place. First the instrument panel (I decided to use the resin panel vs. the photoetch one).
Using JB Kwik Weld 2-part epoxy, I secured the MDC cockpit into place.
Cleaning up the rear sill will be the next order of business.
The pit sure does look nice in place.
Thanks Clint!
Damian at Scale Ordnance Works was kind enough to send me a set of his resin/metal-core landing gear for this build.
I installed the rear sill insert with the battery box. The rear sill has been painted but not yet weathered.
I'm waiting for a few more aftermarket bits to dress up the wheel wells so I don't want to get too far ahead of myself. Just checking out the cockpit with the Revi 16B gun sight in place...
Fantastic work this far John!
:P1:
:P1:
i see it, but i don't believe it. Wow. that looks great!
Makes you want to shrink yourself and hop in, doesn’t it?
Stikpusher wrote:Makes you want to shrink yourself and hop in, doesn’t it?
:yikes: :that:
Incredible work!
