Bruce that is a beauty! And, indeed small. Flying those took guts, flying those into battle took even more!
Bro. Eaton, wow, that is looking great.
Classic Biplane Duelists
Re: Classic Biplane Duelists
We have paint on the kazoo! Let's see more, Bruce! Looking fantastic so far.
It's looking really good Bruce!
And looking sexy, smooth, and luxurious!
... and oily, too. The engines leaked fluids all over the place. Truly though thank you so much, Ken. Sincerely.
Thanks, Lyle; thanks, Tom (I have more to show later today, working on wings); thanks, Clint!
Bruce,
watching the last building episode, I just tell this once.
The paintwork so far on the Triplane is probably your best paintwork so far of all the builds I have seen.
It is outstanding, it looks authentic, it's like done 100 years ago, the nuance, all of it
This is to be a masterbuild Bruce, it is, keep the speed on! :-)
Kari! What you wrote above means the world to me. I knew from the start assembly would be the lesser challenge; the major challenge would be painting. I revere your work both as a builder and as a painter. I have kept copies of your cockpit and exterior work, and I would state for the record that my ability was strengthened directly from contact with your projects. I believe like you like many here I devote myself to a private goal within the work itself, and here for me it is to recreate the softly casual blending of colors used to paint the canvas and linen.
Center Wing & Supports
Please correct me, I think the upper “gun area” is a “fairing, cowling” forward of the cockpit. I have attempted to smooth the form Aurora created which looks nothing like the actual piece. I believe once the guns are mounted this will be acceptable. Not accurate. Acceptable.
Working on the “gun area” necessitated me to go back and forth between construction and painting. I switched from Tamiya Deck Tan (XF-55) to Gunze Tan. Gunze is tougher. Priming was very important as I am combining layers of paint. I am using Mr Base White with literally a few drops of Mr Leveling thinner as a primer—like gessoing canvas.
For the moment, I settled on the Eduard cowling with the Eduard engine combination. Both cowlings fit. When I adjusted the inner struts, I chipped some paint.
I know the inner struts are too beefy, and I am debating whether I should remove them (one end was glued down to facilitate alignment) and thin them to scale. All along I have been engaged in this accuracy debate with the kit.
That’s a good looking little Fokker Bruce.
Fine work, Bruce.
