1/48 Tamiya Zero A6M5c
Any subject, any scale, as long as it's a Tamiya kit.
Re: 1/48 Tamiya Zero A6M5c
Stuart wrote:
Well I kinda meant the build rather than the overspray, but I think you plan will work.
Oh.
He just getting it ready for the yellow flames that happen when a Zero gets hit... :giggles:
Stikpusher wrote:He just getting it ready for the yellow flames that happen when a Zero gets hit... :giggles:
:ggun: :Bur2:
This little beauty is not going down without a fight. Kit decals split and came apart. Contacted Tamiya USA and the gentleman kindly sent me a new set, sealed in a factory bag - I guess. Darn near giddy with excitement. Cut out the Hinomaru and yes, the two that I tried came apart as well. Not sure I've seen this with Tamiya decals before.
Anyway, I can cut masks for the hinomaru and such. I'm good at circles.
But, I'm looking for a font of the Japanese numbers used on the fuselage codes, so I can print those if needed.
Anyone know of any?
Man that's a pain in the arse Lyle!
Most likely have to scan those and print them.Or ask some one who may have them. Like me.
I did V-103 but all I used was the number and the stars on the tail from the decal sheet. Here's the instructions for painting.
Yeah, Stuart, like a Hoover vac! John, thanks. I was able to use the tail codes. Maybe pics tomorrow.
Lyle, did you shake the box too hard, is that what's causing trouble?
Must have! This decal sheet came from Tamiya USA with a couple of replacement parts. It wasn’t laid flat in the box, oh well.
Why not look for an AM decal set for your Zero?
Return to “The 'shake it & bake it' - Tamiya 2021”
