Thanks! Wish I had the same confidence in my abilities that you do.Stikpusher wrote:Well, I’m sure that with your skill level, you’ll appropriately deal with any challenging issues such as the intake, as you encounter them.
Medic's Prowler
Re: Medic's Prowler
Re: Medic's Prowler
We just see your results… not your ordeal…
- jelliott523
Re: Medic's Prowler
I may be coming into this a bit late, but yeah, can definitely see the issue with the intakes, not even sure aftermarket sets would correct that...if they're even available. It even looks like the intake area on the right side is a bit longer and differently shaped than the one on the left.
Re: Medic's Prowler
Yeah it is. They have resin intakes with covers but they've been out of stock for a long time. I'll figure out a way to fix them.
Re: Medic's Prowler
Hey admins!! Can someone move this to the regular aircraft threads? It's really hard to find here.
Re: Medic's Prowler
Moved here. Okay?
Re: Medic's Prowler
Yep! Thanks!
Re: Medic's Prowler
Wow. Can't believe that I haven't updated this in a while. I did get the intakes on. Still need to fill and sand them.
Re: Medic's Prowler
While at Nationals I scored big time with an Avionix resin wing fold. I got it for $10!!! It's a complete replacement wing too!
Re: Medic's Prowler
The Aires cockpit has been primed and ready for paint. I test fitted it into the fuselage today and it doesn't look like it's going to be too bad of a fit. I've started painting the seats as well.
