Special request build, 1/48 La-5
Re: Special request build, 1/48 La-5
сделано?
Bunch of wisenheimers here… :tease:
Stuart wrote:That went together well!
It is indeed. The perfect kit for a speed build
tempestjohnny wrote:That was quick
It’s getting there… by this evening I should have all the main construction done
Medicman71 wrote:That's it? I thought you'd have it done already. :giggles:
:ballbat: :ballbat: :ballbat:
LyleW wrote:Mike, I was thinking the same thing. After all, he IS retired....
Coming along nicely, Carlos. But, let's pick it up a bit, okay?
Sir, YES SIR!
jeaton01 wrote:сделано?
скоро товарищ
stand by for progress report… :clockwatch:
Да, очень хорошо. Но этот американский Бакару опасен. Дайте ему широкое причал.
This morning after the gym I sanded the fuselage seams after letting that dry overnite. Then I added the wings…
And then I added the chin radiator, main gear well center plate, and the tail wheel mount. I also added some strip styrene shims at the rear of the wing to fill a gap there
I had to putty some small openings in the wing front that are a carry over from the common La-5/La-7 molds that should only be present on the La-7. I’m letting those dry before I sand them and resume adding the last assemblies.
More to come later on…
:giggles: :giggles: :giggles:
One ping only… :whistle:
So basic construction is now done. All that’s left to glue in place are the usual breakables: landing gear, pitot tube, antenna mast, and the bombs…
All ready to start painting later this evening…
Yes, very good. But this American Buckaroo is dangerous, give him a wide berth!
Da, Lyle!
But the model looks good, Carlos.
Thanks John. This is a fun little build.
Da, Lyle!
Some things in here do not react well to bullets.
Looking good, Carlos! :shoutout:
