1/48 Hasegawa Pearl Harbor Zero (Niihau Incident) FINISHED
lawdog114
Post by lawdog114 »
This may be a first for me, building the same subject back-to-back. After building a Hasegawa Model A6M3 Model 22 (ok..not exactly the same), I decided I needed a Pearl Harbor Model 21 Zero in my collection. During research for this endeavor, I came across a story I read about years ago. It involved Airman First Class Shigenori Nishikaichi, who piloted A6M2b "BII-120" from carrier Hiryu during the attack on Pearl Harbor.
Nishikaichi was part of the second wave attack on Pearl Harbor and was tasked with bomber escort and subsequent attacks on airfields. His plane was hit and was losing fuel rapidly. Instead of trying to make it back to Hiryu, he opted to make an emergency landing on Niihau Island, which is the western-most Hawaiian island. Japanese intel mistakenly thought the island was uninhabited and chose it as a destination for damaged Japanese planes to land and await rescue. On Nishikaiachi's landing, his wheels caught a fence and the zero bellied in which damaged it beyond repair. He would later try to burn the plane but only succeeded in destroying the cockpit (below).
After the landing, a local farmer on the island took the dazed pilot's pistol and papework. What happened over the next few days would be one of the deciding factors regarding the controversial interment of Japanese Americans during WW2. To condense a relatively long story for our purposes here, Nishikaiachi enlisted (more like brainwashed) the assistance of a local farmer of Japanese ancestry and the pair made vain attempts at trying to get his paperwork back from the initial farmer so Nishikaiachi could escape. Locals eventually became aware of the attack on Pearl Harbor and had no interest in aiding Hishikaiachi in his endeavor. Nishikaiachi, along with the Japanese farmer, then chose to use intimdation and force to retrieve the property. They found some guns and even retrieved the machine guns from the Zero as an additional persuasive measure. They held the islanders hostage and a confrontation eventually took place where Nishikaiachi was "body-slammed" into a stone wall by an immense Hawaiian Cowboy named "Ben" Kanahele. During this struggle, Nishikaiachi managed to pull a pistol from his boot and shoot Ben three times in the process. This apparently only angered him further. Ben's wife then slit the injured pilot's throat which then ended his life. His Japanese cohort then took his own life.
Interestingly, Ben Kanahele was awarded a Medal of Merit and a Purple Heart for his actions. Nishikaiachi was recognized as well and a statue in his honor has been erected in his hometown in Japan. As I indicated earlier, US authorities got wind of what happened and it allegedly played a part in the decision for the interment.
These are the type of stories that inpsire me........modeling history. I shall endeavor to build BII-120 as it appeared on the Hiryu before take off on the day of infamy.
Now on to the model. I found a Model 21 on Ebay relatively cheap. It's the training version but has the necessary parts to build a normal Model 21. I have an old Berna decal sheet left over from my Sakai build which will allow me the ability to piece together the markings needed. Aftermarket will consist of an Ultracast seat.
I figure BII-120 was an early Mitsubishi-built Zero and was probably in new condition. I will weather accordingly. The cockpit was first. I used XF-71 Cockpit Green with a touch of XF-49 Khaki to brown it up a bit. The dials are the kit decals. The OOB pit decent and the Ultracast seat goes along way in improving it. If you would like to see how I do my cockpits, see my SBD Dauntless thread in here.
It wasn't long before I got to the airframe. These are fairly simple. Here we have a test fit.
All looked good on test fit, but I ended up have some minor wing root issues when I later primered the joints. The wing was slightly thicker than the root itself which left a step, so I had to do some sanding. Perhaps operator error, but I recall similar issues with my Sakai zero.
Next I rig the Sakae 12. Stay tuned...
Joe
Re: 1/48 Hasegawa Pearl Harbor Zero (Niihau Incident) WIP
Here we Go ! :-)
lawdog114
Post by lawdog114 »
I got some work done yesterday. I started with rigging the Sakae 12. I did it the exact same way as I did the A6M3 22 zero, only this time, I sprayed the rods and contact points black before gluing it to the engine. Mistake.....This made it very hard to see where to attach the fuse wire to the ignition points. Anyways, I got it rigged.
After a wash and a blast of X-19 Smoke..
A test fit in the cowl...what a difference the wires make...
On to the paint scheme. From now on I will paint in the Hinomarus on Japanese subjects. This is easily achieved with a circle template and a fresh Exacto. I also sprayed in the blue Hiryu fuselage bands with XF-8 Flat Blue lightened with XF-2 Flat White until it matched the spare Hasgawa decal sheet I had. This was then taped off to be ready for the color scheme...
It was then time for the much controversial early "Ame-hiro" Zero color. I've seen everything from Model Master SAC Bomber Tan to Floquil Old Concrete for this elusive color. To each their own but my eye prefers XF-76 IJN Grey Green. Here's how it looks straight from the bottle with my particular lighting situation.
I lightened the control surfaces by adding XF-2 Flat White to the base color and I did some light condensation streaking as well. This was followed up with a postshade around the engine and control surfaces, I also sprayed the cowl XF-1 Flat Black mixed with XF-8 Flat Blue to make my interpretation of Mitsubishi Cowl Black.
Thats where I left off...stay tuned for more soon...
Joe
Manny1943
Post by Manny1943 »
I Iove your zero and want to make a proper base for it that helps tell the strange story of this forgotten footnote in the story of the attack on Pearl Harbor...
This should be good! Beautiful work so far!
lawdog114
Post by lawdog114 »
Manny1943 wrote:I Iove your zero and want to make a proper base for it that helps tell the strange story of this forgotten footnote in the story of the attack on Pearl Harbor...
Thanks Manny... I do intend to put a pilot figure standing next to it. I may have to source a sliver of carrier deck real estate from somewhere.
Thanks Stik...
lawdog114
Post by lawdog114 »
I'm in for a quick update. I removed the tape and was pleased with the results. Gotta love Tamiya tape. Then the "OCD" bug hit me and I decided I didn't like the wing root seams which had uneven gaps at certain angles. It just wasn't my best work. I originally thought they were passable but I changed my mind. I ended up taping "everything" off except for the offending seams at which I ended up using the Squadron putty/acetone trick to fill the seams. I then sanded the crap out of the wingroots and repeated all painting steps. Next time I build one I will fuse the upper wings to the wing root first, then add the lower wing. Interestingly I did not have these issues with the A6M3 Model 22. I suspect the parts a different for the two versions.
I also took the opportunity to paint in the wing-walk warning stripes.
Once finished with the "repairs", I sprayed a few coats of Alclad Gloss. As with pretty much all of my Japanese aircraft, The decals for Nishikaiachi's BII-120 are a hodge-podge of various sheets I had in the spare decal bin. The BII-120 was pieced together from a Berna decal sheet.
This one is in the home stretch. I found a nice rendering of the top of the Hiryu so I will try to recreate a section of it for the base.
Joe
Joe, quite the story and quite a build! Well done, sir.
Manny1943
Post by Manny1943 »
Nice improvement...a comparison of before and after shows the unsightly gap...
I love your Zero and want to crash-land it on a remote Hawaiian island after I attack Pearl Harbor to create create panic and confusion among the native population until they kill me...
