Monogram 1/48 F-106 Delta Dart from 1983
Re: Monogram 1/48 F-106 Delta Dart from 1983
Thanks, Gary. I just heard back from Chris Loney with that same info.
Now, do I order them, go to the post office, get a money ordrer, etc. or do I put on the big boy panties, put a new blade in the scapel, grab some bandaids and have at it?
You're welcome Lyle. I say give 'em a try. They will make the job so much easier. Just be sure to dip the mask piece into some soapy water before placing it on the canopy. It can then be moved into position, patted down and any air bubbles "eased over" to the edges. They can also be slightly stretched (I've used a rounded toothpick to sort of push them over) if you need it just a tad closer to the canopy frame. Burnish the edges with a tool before painting, and carefully lift at a corner with a knife point or pick when done to reveal your nice, neat work. The F-106 is a good one to try an EZ mask, not much there to deal with. :wink:
I spent a day or so of my bench tiime gluing, sanding, priming....you know the drill.....I am quite happy with the reslults.
Pretty much how I spent my day as well Lyle. Looks good!
Looking great Lyle! I've always wanted one of these to go with my F-102.
cbaltrin wrote: ↑Mon Feb 06, 2023 11:26 am Pretty much how I spent my day as well Lyle. Looks good!
I think I’m done with this piece...just a weird arrangement on the fuselage and wing.
Medicman71 wrote: ↑Mon Feb 06, 2023 11:42 am Looking great Lyle! I've always wanted one of these to go with my F-102.
Thanks, Mike. You should get one,
Looking good Lyle!
LyleW wrote: ↑Mon Feb 06, 2023 9:01 am
QUESTION
What are the chances of the makss for the Trumpeter 1/48 F-106 fitting this Monogram kit?
You're supposed to mask canopies? :wow:
Naw, just paint ‘em, then go over the panes with some clear paint. Works every time!
That clear paint is useful stuff!
:rofl:
