Sum Bitch 2nd Class -4
Re: Sum Bitch 2nd Class -4
BlackSheep214 wrote: Sun Mar 05, 2023 1:15 pm
mustang1989 wrote: Sat Mar 04, 2023 9:05 pm That hook and tailwheel look like you could break either one off handling that thing while painting.
Yup. The tail hook is be installed in Step 3 before closing up the fuselage.
Naaah!! You've got this Tom!!
A question regarding inner leading edge slats. Are they red just as the inner surfaces of the dive flaps?
Black and white pic but it looks like it's wing color
Looks like the bottoms are Intermediate Blue
An educated guess says that the upper surface of the slat well would be in Sea Blue to match the adjacent area.
Found another original color photo… yup, upper surfaces are Sea Blue
Great photo, Carlos.
Thanks John. I know that there are some great color photos of the Helldiver out there to be found, but this one is just gorgeous.
Thank you, all. I kind of figured that's what the colors were.
I could make a poster out of that pic!
Last night's bits and bobs progress...
Interestingly enough, the wheel hubs are designated as Zinc Chromate Green
Canopy pieces. They weren't terrible to mask. Air Deflector installed on main canopy.
Life raft stowage....
Displacement gear for bombs
Tail rudder and cowl installed.
Rear MG all painted up! I chose to use Gunmetal instead of Flat Black as assigned on instruction guide.
Other colors used:
Zinc Chromate Green
Flat Black triggers
Red
Aircraft Grey
