Thanks Bruce! PPP and wet q-tips are my go to for small gaps. I tend to use Revell basic putty for steps and sink marks etc. I've only tried milliput once. I need to play with it more - the one time I used it it was very hard and unworkable - probably down to my mixing.speedgraflex wrote: ↑Wed Mar 08, 2023 9:42 pm Hey Stuart, If you really get down to it—PPP and wet Q-tips to smooth it prior to setting is perfect for small gaps, and Milliput is perfect for holding larger sections. I also will follow up once the putty hardens with a bead of superglue which is a trick of my Dad’s as well. This smooths the seam out as the glue self-levels. My Dad would apply SG with a thin new plastic tip. Anyway—I am psyched to see your work, dude! This project is super!
Stuart's Builds - Tornado Finished - almost.
Re: Stuart's Builds - Tornado Started
Milliput gets hard with age, that's why I use Epoxysculpt. It ages but not nearly so fast.
Holy Putty Batman! Looking good !
Yea, not sure what goes bad first, Milliput or Maskol?
I bought Milliput once...
- Gary Brantley
Stuart, that's some great progress on a cool airplane!
I've always admired the Tornados; the first time I heard of the type was while reading Tom Clancy's "Red Storm Rising". Keep up the great work, it's really rocking!
Did you ever read Sir John Hackett’s late 1970’s speculative fiction work, “The Third World War”? I remember reading about Tornados in that book several years before Red Storm Rising was published. The first chapter of Hackett’s book is a series of Day One first person experience scenarios, including a Luftwaffe Tornado pilot. I don’t recall if that was the first time that I had read of the type though, as I was big into reading all sorts of then current defense publications that I could get my hands on. I still have the Armed Forces Journal 1983 edition of the Soviet Threat issue.
Now Stuart, go get that putty cleaned up!
- Gary Brantley
Shelf life of 2 years. I use it often enough that this isn’t a problem for me.
Advantages as I see them are—smoothing with water, faster hardening time, low to no odor.
Full details here, if you are interested:
https://davidneat.wordpress.com/tag/mil ... helf-life/
To each his own; I have purchased many boxes of Milliput over the past years.
I tended to get a year or two more out of my tubes of Squadron putty. So far Tamiya has also given me a bit longer shelf life as well. But I would like to give it a try sometime since Hobby Lobby carries the stuff and it’s decently priced there.speedgraflex wrote: ↑Fri Mar 10, 2023 3:30 pmShelf life of 2 years. I use it often enough that this isn’t a problem for me.
