It doesn't happen often with me but I've had it happen on occasion.Stikpusher wrote: ↑Mon May 29, 2023 9:41 am Great work on the camo!
Interesting to hear that the Tamiya Lacquer paints are giving problems with tip dry for you guys. So far I have had no such similar problems with them when airbrushing.
CB's Monogram 1/48 A-1H Skyraider Build
Re: CB's Monogram 1/48 A-1H Skyraider Build
Thanks Carlos. I guess the tip drying was to be expected with light grey and spraying at 40 psi and the nozzle closed almost all the way downStikpusher wrote: ↑Mon May 29, 2023 9:41 am Great work on the camo!
I was trying to get as tight of an overspay affect as I could. painting the the underside color last can be a challenge...
Nice work!
Thanks Lyle!
Moving on to some less fun stuff.. I noticed yesterday that one gear strut had the wheel axle broken off, so I had to replace it. My hand held lathe came in handy for making the new axle
Nice save. You done yet?
I don't know if you said, but what gloss are you using? I've never gotten that kinda gloss.
I'm using Tamiya TS-13 Rattle Can Clear. I warmed up the can in hot water before spraying. Can should feel very warm in your hand before spraying -- almost like a hand warmer. It was a bit chilly in the work shop as well so I warmed up the fuselage with a hair drying right before spraying -- first time I ever did that but I think it actually did help.
Getting close...
The paint looks real nice, Chris.
