Thank you. Primer is on. Probably won't get to the color until Saturday. It is a pretty neat kit. Not a lot of locating pins and help. A LOT of but joints, but things generally fit pretty well.Brandons_Iron wrote: ↑Thu Jul 13, 2023 8:54 am Man, what a great thread. I have been missing out. I have this in the stash and I have learned a ton from this thread already. Great work and information here. Looking forward to seeing more.
AMT Constrction Bulldozer 1/25
Re: AMT Constrction Bulldozer 1/25
I like the idea of the different shades of yellow. There's a fella that I know on another forum that's priming a Panther in different shades of primer to get the effects that hes after as far as different shades of paint goes. You just have to go light on the color coats to get the desired effects.
Check it out:
Check it out:
Thanks, Joe...That's a cool picture. I used some gray and black. Did not have any red primer.
Second coat of Rust-O-leum Farm & Implement Caterpillar Yellow is on. I do not like this stuff simply because it is enamel and takes 24 hours to dry to handle and probably longer to completely cure out. Covers pretty well, though. Used to the Tamiya "instant drying" stuff.
I'm used to long cure outs Lyle. Just leave them to gas out and work on another area of the build in the mean time and you'll be good bro.
Progress is coming along well on this one.
That is what I'm doing. Hence the 1/72 Sopwith. . . . Also, the wife has a doc appt on Monday and Tuesday, and since I like to come down to the Piddle Palace in the mornings, it will have plenty of time.mustang1989 wrote: ↑Sun Jul 16, 2023 7:28 am I'm used to long cure outs Lyle. Just leave them to gas out and work on another area of the build in the mean time and you'll be good bro.
Progress is coming along well on this one.![]()
- Brandons_Iron
- Master Member
I agree with disliking the cure time of some paints. I went ahead some time ago and purchased a dehydrator that I place all my painted parts in and speed dry them. I can take something I wouldn't touch in a week and have it full cured in hours. They will change the way you work.
BrandonK
I’ve been seeing a lot about these on a couple of FB groups. I have no room for anything else. It is interesting though.
Don't need that around here, most of the year. Just put your build outside in the desert sun and the paint dries real quick in the dry desert air...Brandons_Iron wrote: ↑Sun Jul 16, 2023 9:56 am I agree with disliking the cure time of some paints. I went ahead some time ago and purchased a dehydrator that I place all my painted parts in and speed dry them. I can take something I wouldn't touch in a week and have it full cured in hours. They will change the way you work.
- Handiabled
- Master Member
This is coming along great Lyle!
