Revell 1/48 F-14A Tomcat
Re: Revell 1/48 F-14A Tomcat
The wing looks good! Keep up the great work!
coming along quite nicely! Looks great.
- SigEp Ziggy
Your fellow modeler,
Shane
Shane
Looks really good Ziggy! Taking on the beat up look of the TPS paint jobs at sea on a cruise.
Looks good!
- SigEp Ziggy
Finally finished the wings and mocked them up between the fuselage halves, also I added a piece of brass tubing for a gun barrel
Shane
Shane
- SigEp Ziggy
Well, I should have done research FIRST and then scratch built a gun barrel. Now I'm stuck with my mistake as removing the brass tube would cause too much damage, so it will be inaccurate.
Shane
Shane
You can't get some debonder to dissolve CA glue? Or did you use epoxy to attach the brass?
- SigEp Ziggy
Stikpusher, I carved it into the plastic and it is sandwiched between two parts because there are two version of the gun panel, hard to see in my blurry photo
Shane
Shane
Understood Shane. Not sure what to suggest at this point…
