Heinkel 162
wasabi
Heinkel 162
Post by wasabi »
Hi,
I didnt put aside the build of the Yakovlev but just needed an interlude.
This is the very good and easy Tamiya model with the Quickboost bang seat, plus other scratch-built items. As always Tamiya decals are too thick...
On the actual He-162 the clear part of the canopy was set on a metal frame and screwed from the outside. To reproduce the particularity, I just painted the frame from the inside.
Painting was done using Xtracrylics which, despite very fine pigments, is a pain in the ass to airbrush, clogging the A/B every 5 minutes. The base was made using Paris plaster, balsa strips and a mix of grass mats from Imthurn and Heki. The oil drum comes from Brengun.
My build is far from perfect, but let's say that I am finally able to build and paint the way I want without having too many technical limitations.
Hope you like it.
Antoine
Re: Heinkel 162
That is a perfect dio for this! Beautiful build. I may have to go get one of these. I've almost bought them several times.
CallSignOWL
Re: Heinkel 162
Post by CallSignOWL »
very well done! Salamanders are such odd little planes
Fermis
Re: Heinkel 162
Post by Fermis »
Great!!! :kissing:
Re: Heinkel 162
wasabi wrote:Hi,
I didnt put aside the build of the Yakovlev but just needed an interlude. (...)
This interlude paid off full. What a great Salamander, I really like it. And the base matches perfectly.
Thank you for sharing, Antoine!
Re: Heinkel 162
As stunning as that build is (and it IS brilliant- well done) I'm even more impressed with the base - it's fantastic!
Re: Heinkel 162
Great model Wasabi, I love how you did the rivets on the windows, an difficult and often overlooked detail How did you do that?
wasabi
Re: Heinkel 162
Post by wasabi »
Thank you guys for your kind words
portman wrote:As stunning as that build is (and it IS brilliant- well done) I'm even more impressed with the base - it's fantastic!
Thanks, it took me at least a month just for the base, but I am not a fast builder. When thinking about it, the planks are maybe set too regularly.
BorgR3mc0 wrote:Great model Wasabi, I love how you did the rivets on the windows, an difficult and often overlooked detail How did you do that?
To be honest, I have absolutely no idea how I did that :tongue: . When I removed the masks on the canopy, the rivets appeared slightly withe. I guess you could achieve the same result with some pastel work.
