Eduard 1/48 scale Focke-Wulf Fw190A-6
Re: Eduard 1/48 scale Focke-Wulf Fw190A-6
Some late night (11 pm EST) sanding and test fitting. Looks promising.
Oh yeah, test fit the brass gun barrels. They look spectacular prior to test fitting top wing halves. :lashed:
Next to test fit and install weapons bay portion up front.
Do invest in a David Union Ergonomic Pen Sander...
All looking good Tom - sorry to hear to you've been having issues with it.
A preview of metal gun barrels prior to wing tops installed.
Those barrels do look sharp Tom! :shoutout: :shoutout: :shoutout:
Wings halves are glued on. Had to do a bit more sanding to get them to sit right.
Now, I am undecided on which tires to use: plain or spoked type. :hmm:
Wings...
Close up with metal gun barrels from wheel wells.
I'm on a roll tonight... :giggles:
Wings on fuselage!
Minor gaps on both sides. I dont want to force them but nothing a but of putty can cure it. :lashed:
Now it will be easier to position the weapons bay portion where it's suppose to go...
I will install the top back wall part later. First, time to slap on a coat of paint on it. :whistle:
it looks like there should be a slight gap where the cannon fit through the leading edge.
That photo really does show to good effect just how grungy an aircraft gets in the rapid tempo of combat. 👍
