Well as the title said, this is my built of a Messerschmitt bf109 G10 from Jagdgeschwader "Udet" 3.
So with no futher due here is a little recap
Re: Messerschmitt bf109 G10
Sorry I feel stupid i can't find a way to upload pictures...do you have a "howto" section?
Hi this is Bruce one of the mods here.
Here we use third party photo hosting sites that allow you to link to your images. I personally use “Postimages,” which according to the site will always be free.
https://postimages.org/
Upload to third party such as Postimages.
Copy the link or use the button to copy the link to your photo. Make sure you choose the “Forums” link.
Paste the link into your post.
Edit the link. You only want to post the section that begins with [img]
We have all been there, Full Metal. Looks like one change you need going forward is to select “Hot link for forum” links
Lt. Barkhorn’s Bf 109 F from 4./ JG 52, taken in July 1942 in Artemovsk. Seated on the wing is 1. Wart Fw. Kusterer.
I know it’s not a G, here’s a G-10!
A question: is the interior that looks a brighter green than RLM 02 to correct for scale effect, or is that correct? I’ve given up on several projects trying to get RLM colors to work for me. I have to add your cockpit looks spot on.
Bruce Beat me too it
Sorry Greg, I forgot to mention when I suggested the forum that we don't have a attachments function and you'll have to use a hosting site like postimages (I use my wordpress blog) - it sounds a PITA but it's actually very easy when you get into the swing of it and saves memory space on the forum.
Awesome that you've managed to post up photos, but if you want bigger images you can either use the hot links as Bruce (speedgraflex) suggested, or this method.
Once you click on the postimages link you get an option to resize if you need it.
I normally choose large for forum use...
Then click choose images obviously. When you get the links copy this one...
Then go to the post and click the add image button to get img brackets - like you've done already.
And then just insert the image link - again like you've done already.
And then you'll get a bigger image - as I said, it sounds a pain but it actually takes longer to explain than to do once you get in the swing of it.
Hope that helps - good to see this build again.
Cheers!
Stuart (Arnie).
Cheers!
Stuart (Arnie).
Yup. Bruce is spot on on which tab to use forums.
I always use the second link up, “hotline for websites”….
That one works too!
