The Children of Doom
Re: The Children of Doom
Great pic. Also noticed a few Wildcats at the front with the extra large roundels
tempestjohnny wrote: Fri Aug 07, 2026 3:56 am Great pic. Also noticed a few Wildcats at the front with the extra large roundels
Yup. And notice that one SBD has the original 4 position stars, while another has the small pre war fuselage star. All sorts of “regulation” markings seen at the same time, and certainly not uniform across the Air Group.
BlackSheep214 wrote: Thu Aug 06, 2026 7:22 pm I knew the SBDS had roundels larger than the other, but never knew they were applied to the P-47s.
Yes they were. At the factory on the assembly line, the national insignia stars were applied in the standard regulations four positions: upper left wing, lower right wing, each side of fuselage rear
And the aircraft were delivered with this configuration
Once assigned in England the white tail bands, cowling, and yellow fuselage star outline border were added
But at some early point in England the over size lower left wing stars were added
But I don’t have hard dates on this. All I know is that it was in Spring 1943 when the P-47s began combat operations.
Interesting. I didn't know any of that. Guess you really do learn something everyday. :hmm:
Medicman71 wrote: Sat Aug 08, 2026 12:18 pm Interesting. I didn't know any of that. Guess you really do learn something everyday. :hmm:
The internet can be a fun place to get lost when searching for some tidbit of info… and enlightening during those dives down into the rabbit hole.
Stikpusher wrote: Sat Aug 08, 2026 7:13 pm
What's funny is that there's nothing about it in the P-47 Detail and Scale book and I only found one pic of the yellow bordered star.
Looking really nice Carlos!
Thank you Stuart!
So my latest batch of progress photos…
During the week I applied Tamiya Liquid Panel Liner then cleaned it up. Afterwards I then airbrushed on a flat clear coat
A couple of days ago I replaced the kit gun barrels with some Albion brass tubing of an appropriate diameter and cut to the proper lengths, and then glued them in place.
Today I painted the gun barrels with Metalizer Steel
I also today finished painting the exhaust stacks and turbocharger exhaust shroud, among other small details
That’s all for today… finish line is approaching rapidly!!!
Jugs look so different with jus the blue roundel instead of the stars and bars
Return to “Shelf of Someday”
