Purely random choice I assure you
Monogram 1:48 F-14A (IW)
Re: Monogram 1:48 F-14A (IW)
ha ha, nobody noticed that when I posted pictures of the cleaned up wheels , it was the non-ejector-pinned side of the wheels that was shown
Some very minor progress on the Tomcat was made yesterday evening.
I installed a new fuel dump mast for one thing.
Next I got the 3d printed burner can inserts glued in place.
Then I painted the inside of the , ehhhh, what should I call them.. exhaust nozzle end caps? Well I painted the insides gloss black so I can Alclad them later . They are shown here as it they were attached but they are just sitting their but not glued. Still contemplating how to pain the visible portion of the engines on this. Anyone who has seen the rear end of an F-14A knows how near impossible it is to replicate all that is going on there with paint.
I also future dipped the windscreen in so I can get that installed...
Progress is looking good Chris!
The variable opening nozzle end parts of the afterburner are referred to as petals, like on a flower. At least on some engine types.
Nice work on the engines!
Wonderful work, Chris. It’s a pleasure to watch such clean and tidy construction. Although it’s not been a specific interest before now, I’m curious to know how you plan to paint the exhausts.
And yes, I was completely convinced you had removed the injector pins and did not really see that the interior wheel pattern changed just enough to indicate that was the other side.
Thanks Carlos. On the F-110's we had in the "B" models, we called them Turkey Feathers. That description does not seem to fit the appearance of the TF-30 however. Petals does seem more appropriate here.Stikpusher wrote: ↑Tue Aug 18, 2026 9:53 am Progress is looking good Chris!The variable opening nozzle end parts of the afterburner are referred to as petals, like on a flower. At least on some engine types.
Thanks Bruce. Not quite sure on the exhaust nozzle/petal painting. As for the masking, it would be easiest to paint it first, then mask it and paint the fuselage. Problem is keeping the mask from peeling up for all the time it would take to paint and decal and clear coat and, dare I say, weather it up...speedgraflex wrote: ↑Tue Aug 18, 2026 12:59 pmWonderful work, Chris. It’s a pleasure to watch such clean and tidy construction. Although it’s not been a specific interest before now, I’m curious to know how you plan to paint the exhausts.
Thanks for taking the time to answer my question, Chris. I recall seeing the multicolored results of other projects which always reminded me of peacock feathers in their variegation but after the modeling magic (hard work) happened. It’s also good to read about the color choices and mixes.
They are called the same thing on the Pratt & Whitney F-100 turbofans. USAF mechanics tend to leave them off of those on F-15 Eagles and on the GE F-110s used on the B-1.cbaltrin wrote: ↑Tue Aug 18, 2026 2:49 pmThanks Carlos. On the F-110's we had in the "B" models, we called them Turkey Feathers. That description does not seem to fit the appearance of the TF-30 however. Petals does seem more appropriate here.Stikpusher wrote: ↑Tue Aug 18, 2026 9:53 am Progress is looking good Chris!The variable opening nozzle end parts of the afterburner are referred to as petals, like on a flower. At least on some engine types.
Looking them up online, apparently the technical term is interlocking flaps.
I tried to accent the flap/spoiler detail on the wings. I knew from the past that the old monogram details were too soft to successfully do this so I am not sure why I tried
At any rate, I repainted the wings as a result. Then I could not resist 'test fitting' stuff. I may try to re-wash the wings, but being careful to avoid the spoilers as that is the main problem area.
