Matchbox 1/72 Saab J29 F Tunnan by speedgraflex
Re: Matchbox 1/72 Saab J29 F Tunnan by speedgraflex
You're absolutely right about the wing being painted, Carlos. I believe that's the same airframe Stuart reference earlier. The final version (“F”) has a Swedish designed afterburner. The photos are good. This is the one they kept in operational status.
I was too tired to post any explanation, but this was a test, and I'm afraid I still don't much care for AK markers. When I rubbed the paint the next day it came off quite easily. Now I know there's no primer underneath but I still think there should be some surface adhesion.
I've sanded this area down and will correct with primer. I'm going to do the outside first.
I finally found my pic Bruce. Here is my Tunnan from 1983-1984. More then likely its the Heller kit.
- Bolleken
- Master Member
Bruce, my friend, no news here? Looking forward to your progress on that Saab Tunan.
Marius, allow me to start with this 300 dpi scan of the decal sheet, which includes the aerobatic markings which would be useful to create masks and templates, then I'll move on to Chapter 2 of this build which is "Things My Father Taught Me."
Chapter 2
Things My Dad Taught Me (Model Building)
Maybe every one does this, but I never see it. It's using a hot glue to melt and finesse rough plastic. I have only seen this done by one internet modeler who likes to build old kits and that may be the reason. However, this is something my Dad taught me to do and with a kit like this, it's the best way to form a compound curve. The nose has been a bit of a challenge in that regard. A great deal of plastic had to be removed. So I literally paint the surface of the plastic with a coat of glue and let that set. That's an important trick that I'll use everywhere, pretty much. I've used it on the seat already and now I'm using it here on the nose area.
Front End Friday
The front end cap is heavily modified. It's carved into form with needle files, and curls of sandpaper. Now it's been painted with glue and you see the surface is partially dissolved. I'll go back over this again with a higher grit from Lyle's box of wonderful sandpapers. Thanks again, Lyle.
The Bottom of the Barrel
Here's how things look down below. More than a bit rough. It's hard for me to keep the areas around the guns completely clean and clear of putty as well as scratches. The guns look a little weird to me, still rough and I'm not sure if drilling out gun barrels has helped. I think so, and I trust Carlos when it comes to details like this. Thank you, Carlos. Maybe I need to enlarge the openings. We'll see.
Front End Friday
Interesting. I have tried that to add a rough texture to plastic with the help of some course sanding sponge, but you are doing the opposite.
That is interesting, too! I can definitely see how that could work if you wanted a matte versus a glossy texture, Chris.
I was careful to place this idea in context from my father because I have really only seen one other model builder do it and that there was one made me feel that it might be an older technique started in the heydays of Revell and Monogram and has been lost to time.
My online source is Greg’s Models (not to be confused with Full Metal Greg). He’s British and has built quite a few of the older Airfix kits that nobody seems to build these days due to their various degrees of complexity, but he also builds newer kits as well.
The way he uses the smoothing technique is the same.
Looking good there Bruce! Since you’re going with a NMF, smoothing out the plastic is highly advisable. I had not thought much about the how before as compared to the why. But then here you mention a coat of glue to smooth it out. I’ve done that before on armor kits to roughen the surface for a cast texture. Which it did overall, however it also left the surface shiny. But here you’re heading in the opposite direction. A buffing after it’s dry with some very fine or ultra fine sanding sponge/block/stick should give you the last preparations needed for the surface. Perhaps multiple coats of your chosen paint, with polishing between each color as well during tha painting process. That is something that I did long ago on another project with good results.
Thanks, Carlos. I’m also using layers of CA over the engraved fuselage fills and giving those the same polishing effect. I’m limiting myself to the fuselage so far, mainly due to reasons of sanity.
What will most likely happen is I’ll add back a few of the simple tiny protrusions on either side of the exterior exhaust in stryrene to keep some sharp details. I’m afraid that using this approach runs the risk of raised surface smoothing.
I’m still not sure how to fix the gun covers.
