My Dauntless twofer are COMPLETE
Re: My Dauntless twofer are COMPLETE
Brandon, those are both superb. Super work. That's one of the best Monogram SBDs I've seen put together. The finish and construction are spot on. AM kit is fabulous as well.
Both are fantastic builds. Good to know info on the Accurate Miniatures kits. I've got 4
- Brandons_Iron
- Master Member
Thanks, guys!
I'll build more AM kits. Now I know what to expect from the assembly process. The kit is very "suggestive" when it comes to placement of things rather than clear and clean "it goes here" guidance like Tamiya. It's best to download the Academy instructions for the rebox as they updated the instructions and corrected many of the problematic areas.
BrandonK
Are they 1/72 scale Dauntless kits? I have a couple of Dauntless kits in 1/48 scale.
- Brandons_Iron
- Master Member
Those are both in 1/48.BlackSheep214 wrote: ↑Wed Nov 04, 2026 12:28 pm Are they 1/72 scale Dauntless kits? I have a couple of Dauntless kits in 1/48 scale.
BrandonK
Beautiful work!! They both look awesome!!
- Brandons_Iron
- Master Member
Thanks, everyone. It's nice to have them done and on display.
BrandonK
I like using PE for dive flaps just as I did on the Helldiver. When I do the Dauntless kits, I will use aftermarket PE dive flaps. I’ll probably pose them both in dive position too. I may look into getting PE a spinning props too.
Check out this guy if you haven't yet: https://www.propblur.com/store/c1/PropBlur.comMain
