Sharkmouth Bf-110c (FINISHED)
Re: Sharkmouth Bf-110c
Steel wool? How do you mean you'll buff things up with steel wool? Curious and eager to learn a new trick or two....
CallSignOWL
Post by CallSignOWL »
Manny1943 wrote: :hmm:
does my zerstorer not pass inspection, Herr Field Marshal? :bag:
CallSignOWL
BlackSheep214 wrote:Steel wool? How do you mean you'll buff things up with steel wool? Curious and eager to learn a new trick or two....
yah, I take a glob of 0000 steel wool (find it in the paint section at at hardware store), and scrub the plane with it. The 0000 is a finishing grit, and it evens out the paint ridges, as well as making things smooth for the gloss coat. Kinda gives things a semi-gloss sheen. You can also use it on BMF to change the tone of the foil
this is the bag I have, I think it was only like 4 bucks or something. Its lasted a long time too!!
Looks like I'm gonna watch this to get a better understanding on what you're trying to achieve using steel wool. I'm guessing more of a worn finish? :oops: :blush: :hmm:
CallSignOWL
BlackSheep214 wrote:Looks like I'm gonna watch this to get a better understanding on what you're trying to achieve using steel wool. I'm guessing more of a worn finish? :oops: :blush: :hmm:
It certainly helps achieve that. But im more focused on getting rid of some of those brush marks! lol
Ill be repainting any spots that get worn away. :)
CallSignOWL
JimD wrote::hmm: I'm guessing this stuff is less abrasive than the steel wool I'm familiar with? Not familiar with it but the words "scrubbing," "model," and "steel wool" terrifies me.
yeah, its not the kitchen scrubber!!
0000 is used for polishing
Kermit
Post by Kermit »
:hmm: I tend to use foam blocks for that. You know, the kinda thing the ladies use to sand, buff and smooth their nails. Buy em at CVS or Riteaid for a buck. They come in all kinds of coarseness. The foam will soften up over time and will follow any curve perfectly.
http://www.alibaba.com/product-detail/h ... 57664.html
Haven't used the 4-oh steel wool on models, but on wood finishes, paint, etc. it does just what Owl said. It will knock down inconsistencies and create a smooth, satin fininsh. Had not thought to try that.
Looking good OWL!
Love the steel wool idea - I've never thought of doing anything like that, and a lot of my brush work could probably use it.
Thanks!
Return to “2015 Big Airfix Groupie GB”
