4x4 MRAP Kinetic 1/35
Re: 4x4 MRAP Kinetic 1/35
Coming along very nicely Thomas. Quite interesting on how Kinetic added some contours not there on the real thing. This thing is starting to take on a real "Mad Max" look.
- Thomas_M
- Admin
Thanks, Stik!
And to my surprise it´s a much taller vehicle than I thought of just a 4-wheeler. I hope to spray the IP soon, I have already done some masking on it. But, realizing that almost nothing will be seen later I prefer laziness to perfectionism here...
- Thomas_M
- Admin
Ok, time for an update!
I almost forgot to do this strange part that goes into the crew room of the MRAP:
Any idea what this could be? Fire extinguisher?
Front doors have been finished. They only need the tinted clear parts added and then are ready to be glued shut. Here is a lst view of their inside face:
Followed the pictures of a real vehicle you guys provided me the links to. Thanks again for those! The placard is from Archer.
I did the door seals (black lines) with a stamp I cut from a piece of insulation foam my wife was working with!
- Thomas_M
- Admin
The dash has been finished:
I first did spray it off-black, then masked dials and IP with 502 Abteilung Liquid Mask. A coat of satin grey did follow, together with some little detail painting and pigments. The computer screen is a picture I found on the Net, resized in Photoshop and printed on our CANON (! Lyle !) colour printer on photo paper. I glued it on using Gator glue.
Neato! Or is that NATO? I like it!
- Thomas_M
- Admin
The non-fitting inserts on the front of the hood have been filled with Magic Sculp and sanded:
Tinted clear parts have been added, together with some PE meshes airbrushed in black. No idea what those are for, but they are in!
Another screen has been added above and in front of the driver:
Also visible tiny PE louvres. Air condition, I guess.
- Thomas_M
- Admin
Some more PE covers added on the outside:
Some gizmo added to the interiour. Looking at pictures of the real vehicle a ton of other equipment is missing! But for I am going to close all doors I am fine with what is given.
Here is what has been done so far on the inside, before adding the dashboard and closing the hull:
More to follow!
More to follow!
Very nice detail work.
- Thomas_M
- Admin
Thank you, Lyle! Just a little bit of drybrushing with oils!
The meshes more likely netting to store stuff. Like a box of Twinkies or something....
