teeny tiny small parts
Paul
Post by Paul »
How do you sand down the small tiny parts that are impossible to hold between your fingers. That escapes me just as much as seeing said same parts.
Re: teeny tiny small parts
The obvious, smart alec comment would be, "Very Carefully!" :drum:
I usually try to hit them as best as I can while they are on the tree. That, or pinch them between fingers and have a go at it.
If you're talking about the mold seam lines on those parts, I usually do that while they are still on the sprue using needle files. I clean up the sprue attachment point usually after the part is glued in place if need be. I have tried using tweezers to hold small parts, but this often results in the small part being launched into oblivion...
59North
Junior Member
Post by 59North »
There is a small 1/72nd gun-sight still attached to a sprue piece held in the clamp. I'll then put a thin abrasive stick to good use:
Paul
Post by Paul »
Alright! Hemostats, I have not thought about getting any of those. Great idea.
59North
Junior Member
Post by 59North »
Paul wrote:Alright! Hemostats, I have not thought about getting any of those. Great idea.
Glad you like it; but, us red-necks just call them clamps. :giggles:
Paul
Post by Paul »
and us old stoners called them something else... :quotes:
tigrazor
Post by tigrazor »
Tweezers!
Invest 1-2 $ more, and you should find a good one.
Locking tweezers also comes to mind.....
