1/48 Tamiya P-47 D-25 RE "Hairless Joe" (FINISHED)
lawdog114
Post by lawdog114 »
Here's something I haven't done in a while, an 8th Air Force topic. I'm way overdo. I've been itching to do a Jug for awhile, so I'm gonna shift gears to two of my favorite subjects, the Tamiya Jug and the 56th FG. So many great pilots, Gabreski, Johnson, Zemke to name a few. Well, I decided on 62 FS David Schilling's "Hairless Joe". Schilling became the 56th CO after Zemke was Pow'ed. On December 23rd 1944, he downed 2 Bf 109 and 3 Fw 190 fighters in one mission. He would ultimately be credited with 22.5 kills. Here's an idea how Hairless Joe looked:
On to the kit. The Tamiya P-47 series is perhaps the greatest thing ever kitted in plastic. It's pure modeling bliss. I will add Ultracast tires and a seat, the latter because I have one on hand. I'll rig the motor too, as I do on all my radials. I have HJ on an Aeromaster "Wolf Pack" sheet.
I started with the cockpit. I used the kit decal for the instrument panel and had no issues. Again, the seat is Ultracast. I came up with my own version of Dull Dark Green that Republic used. I mixed up XF-61 Dark Green with a touch of XF-58 Olive Green.
I then switched gears and worked on the Pratt & Whitney R-2800. All radials need wires,as they look naked without them. Forget Photoetch and try this. Here's a brief "how to". First I assemble the engine and add the gear box, which is temporarily secured with blue tac (gear box painted black for illustration purposes..it's not necessary). Now we need ignition leads. I glue two pieces of .10 styrene together and slice off pieces to represent the leads. These are then Tenaxed around the ring. If your radial doesn't come with this ring around the gearbox, add one with styrene rod.
I then used Alclad Grey and primed the mill. I was ok with this grey shade for the gearbox, so I taped it off and sprayed the rest Alclad Aluminum. Once done, It was time for the wires. These were a copper color on the real thing, so I use the copper striped from an old stereo wire. It's now a matter of cutting the wires to length bending them, and then super-gluing them from the lead to the cylinder.
I usually start off slow, but once you get the hang of the proper lengths, it goes quickly. I can get here in an hour or so....
Now the fun part....paint and weathering. I hand paint the leads then spray everything with a Testor's gloss coat to seal it for a wash. After a Detailer wash, I hit it with Testor's dullcoat. I then finish it off with a blast of X-19 Smoke to give it that smokey used look.
I should be buttoning it up soon.
Joe
Re: 1/48 Tamiya P-47 D-25 RE "Hairless Joe" (Work in Progres
Joe, this is gonna be good! Can't wait for more. And, thanks for the how-to as well. I wish my hands would cooperate.
Doogie
Senior Member
Post by Doogie »
Outstanding work so far.
That's outstanding work on the Pratt & Whitney Radial engine lawman. Gonna have to use your method on the Tamiya P-47 Thunderbolt Razorback kit in my stash. I wanted to do one of two versions - one flown by Lt. George Sutcliffe.
http://www.oldgloryprints.com/Steadfast ... 20Odds.htm
The other piloted by local Syracuse resident Captain Henry J. Miklajcyk. Ace of WWII with 7.5 accredited kills. Shot down and killed, in Air Combat, Nov 2, 1944. Interred at Sacred Heart Cemetery-Syracuse, New York. He also flew P-51 Mustangs too. Syracusan the 2nd and Syracusan the 3rd. No pictures of Syracusan 3 exists. I've even got in contact with "Punchy" Powell for any assistance on the matter. Yeah - THE "Punchy" Powell of the famed Blue Nosed Bastards of Bodney who flew The West "by Gawd" Virginian.
http://modelingmadness.com/scott/decals/ce/ce48126.htm
I'd love to do Sutcliffe's stead but they don't make decals for his aircraft.
LyleW wrote:Joe, this is gonna be good! Can't wait for more. And, thanks for the how-to as well. I wish my hands would cooperate.
Looking absolutely stunning!
And seconding Lyle, very useful the how-to part with the engine wiring!
One day I will also try that... one day...
Man the work you pull off on your pits and motors are really great. You have your process down pat, that's for sure! :shoutout:
wow, what a cool work
You really need to get this book: :Fighters of the 8th Air Force
http://www.barnesandnoble.com/w/fighter ... 2352503286
I've got to get this book too.
http://www.barnesandnoble.com/w/12th-an ... 2352502104
Wow that pit and engine look great!!
lawdog114
Post by lawdog114 »
Thanks all.
Black Sheep, indeed I need to find that 8th AF book. I get alot of my modeling inspiration from books and aviation art. I would also love to do Sutcliffe's ride, but I've never seen decals for it either.
I finished it up the other night. It's in the 56th FG/62FS markings of Colonel David Schilling. Schilling was the 6th leading ace in the 8th Air Force with 22.5 kills, to include 5 in one day. Hairless Joe was his personal mount from July 1944 until his last combat mission in January of 1945. Schilling would survive the war and continue to command the 56th FG. Schilling would died from injuries sustained in a car crash in 1956.
I chose to depict the plane after Schilling's run in with Flak and subsequent crash landing in September of 1944. The port wing reportedly had to be replaced. The upper camo was replaced but the underside was not repainted. Makes for an interesting scheme.
The kit was was a joy with only a few issues. I didn't paricularly like the design and fit of the rear spine. I also had trouble with the starboard wing root for some reason, but I'm sure it was something I screwed up. Putty on a Tamiya Jug...the humanity! This said, I still consider it's sister kit, the Tamiya Razorback, the best plastic model ever made. I have 5 in my stash. I used an Ultracast seat and tires. The decals were Aeromaster and presented no issues. I was worried about the lower oversized stars and bars but I had no trouble. I left the wing pylons empty because I didn't want to add bombs and I hate the 108 gallon paper tanks. I may still add the tear drop tanks but I've only seen those used in the Pacific. If I'm wrong please correct me.
Enough of my yapping. Here's some pics. Comments criticisms welcome....
Joe
