My second dewoitine : D.501 Smeller 1/72
BsYamato
Post by BsYamato »
Started about two weeks ago this second dewoitine old fighter version, i built the 510 probably two year ago.
Not so much work till now but heres the wip :bored:
Box'n'sprues :
The kit, as the 510 it's a rebox of the old heller kits, good quality for the period , raised details out of the control surfaces , few pieces that nees some little detail cure.
Starting from wings and cockpit inner struts
Almost cut off horizontal rudders and glued toward ground
not bad the seat but i prefere more accuracy, then removed side walls and put sonme detail in the bottom and wrapped a plastic sheet into the seat
cutting refine and putty
To the wings :
Added central fuel tank and the four sections in the wings with thinner plastic sheet i have (or not :hmm: ), some detail to add again at next round
The propeller with replaced 20 mm gun (yes, 20 mm!!!) with a brass tube
First arrangement of wall instruments, after i see the wheel and the trhottle was too much forward..
the following week (this..) builded the floor with rudder pedals and cut the IP basement.. here i see some of wall instruments was too much forward :(
The start of control stik, from a stretched sprue
and ready
The excess of sprue at the basement helped the sctratch session giving a good grip :quotes:
cut the excess and in place , glued from the bottom
the other side corrected in some way
I forget about! i filled the inner wings basement in the fuselage with plastic pieces to have a correct inner fuselage !
The two IP finished and the seat with the belts hole done
That's all till now.. for this kit :DH:
Re: My second dewoitine : D.501 Smeller 1/72
Brilliant work Bsy!
especially how you made the control stick!
:that:
Outstanding work!
Bsy is busy with the modifications. Looking good! :yipee:
Great work on that control stick, very delicate but porbably also very visible because the open cockpit.
Great work BSY - I remember your last build of this kit and this one looks like it'll be just as good.
This thing had a 20mm gun? - not bad.
dogfish7
Senior Member
Post by dogfish7 »
That's amazing! :headslap: Don't think I've ever seen an interior scratched in that scale! :popcorn:
So many models.... so little time.
BsYamato
Post by BsYamato »
Many thanks :)
Painting last night after the primer with acrilycs. A drop of clear into the IP instrumets , also thinned clear on the walls for the incoming washing.
The seat and the propeller with a pathetic attempt to reproduce wood
At the next
BsYamato wrote:Many thanks :)
At the next
Oh no, "Pathetic" being too strong word in this case, in my opinion looks very good, especially as it is a 1/72 propeller!
BsYamato
Post by BsYamato »
Out of all is only the probeller but i really fear when...
the albatros round for build :bag:
