1/72 Italeri F-5F
Fermis
Re: 1/72 Italeri F-5F
Post by Fermis »
Stikpusher wrote:
Paul wrote:If you are going with Sundowners then no full load out is needed. They used the F-5F for east coast aggressor training so you get some what of a reprieve there.
Get on it Jezza, whip it good!
Right... I imagine that their standard load would be a captive Sidewinder (live seeker head with an inert motor body) on one wingtip rail, and an ACMI pod on the other rail, and maybe a centerline tank...
Already got one of those!
Paul
Post by Paul »
That turned out right purdy.
Stunning work Fermis! Once again you've blown me away with your outstanding quality!
Thomas_M
Post by Thomas_M »
:shocked:
Wow! That´s a dream of a finish!
:that:
Thomas_M wrote::shocked:
looks so good.
Fermis
Post by Fermis »
Thanks guys....that's the 1/48 AFV Club offering.
I'll be getting under way with this Italeri kit pretty soon. (been working a big job that's consuming all my time, and the heat has been consuming my will to live! :whiteflag: )
Paul
Post by Paul »
Now that you are almost a senior citizen you will find the heat always zaps your will but a couple of shots of single malt will set you up right.
Thomas_M
Post by Thomas_M »
Paul wrote:Now that you are almost a senior citizen you will find the heat always zaps your will but a couple of shots of single malt will set you up right.
As does a nap in a dark, cold, bedroom! :sleep2:
Fermis
Post by Fermis »
Nap shmap...aint nobody got time for that!
Our a/c went out on Friday....90 degrees in the house Friday night :stinky: Not much better over the weekend.
....fixer man is on his way now :dancing:
Ya'll are acting like it's a hundred and twenty degrees out here...
Return to “Member Reviews”
