JKim's Completed Builds (Restored..Again!)
Re: JKim's Completed Builds
Ok... I should finish what I've started and describe the rest of the Blue 16 painting process. After my color modification of the engine cowling, the model was given a gloss coat and the decals were applied. After the decals were sealed with another gloss coat, I tried some salt chip fading. I didn't photograph this part of the build but essentially you give your model surface a coat of water and then sprinkle salt crystals (I like to use ground rock salt) on in random areas. Once dry, you spray a second color over the dried salt. Once you wash off the dried salt crystals, the random spots are revealed. You can use this method to create paint chipping but I like using it to impart a raggedy and spotty fading effect to the upper surfaces.
Here is what the application of salt looks like on a P-38 followed by a photo of the results.
On Blue 16, the effect was subtle. Too subtle and was almost disappeared after the final flat coat was applied.
A dark pastel panel wash (my own mix) was applied to highlight the recessed details. I've heard some opposing opinions on the highlighting of panel lines. I highlight all of my panel lines with some sort of wash. However, I am not of the opinion that this is the most "accurate" way to weather an aircraft but I much prefer the look of a panel line filled with a wash than a panel line that hasn't been filled. In my opinion, an unfilled panel line looks exactly like what it is: a engraved groove upon a plastic surface. The filling of the line with a darker wash serves to highlight the panel but also helps to visually turn a 3-D groove into a 2-D line... if that makes any sense.
The panel wash is sealed with a flat coat. I like how the rivets add some visual interest to the surfaces without being too dramatic. They fade away nicely as you step away from the model.
Very interesting use of the salt chip method... I've only seen it before as bare metal chipping. I like this color spotting effect. :hmm:
Thomas_M
Post by Thomas_M »
I know what a wash is. And I know about pastels. But, how do you make a pastel wash?
Sorry for the silly question...
Stikpusher wrote:Very interesting use of the salt chip method... I've only seen it before as bare metal chipping. I like this color spotting effect. :hmm:
Yes, you can get some interesting effects using this method. It's a bit tedious getting all of the salt off though. Any missed areas will have the tendency to turn white after drying completely so you have to make sure to remove it all prior to application of a clear coat.
Thomas_M wrote:I know what a wash is. And I know about pastels. But, how do you make a pastel wash?
Not silly at all. I make my liquid washes from pastel chalk. I just scrape some powder from an appropriate color piece of chalk, add water and a drop of dishwashing soap to break the surface tension, mix it well and presto! you have a liquid wash that you can run into recessed details like panel lines. The important thing is to use PASTEL chalk not OIL. I've had good results using these...
John, you are a wealth of fresh information and techniques. Thank you for sharing.
Thomas_M
Post by Thomas_M »
:P1:
Absolutely! It´s like a fresh breeze of air reading your so informative posts and see the pictures of amazing builds! Hey, I even thought about to do some modelling again myself!
Just passing on the things that I have recently learned! The internet has truly enabled a new generation of modelers.
Blue 16 inspires me with the Horten. I was not terribly keen on the green-brown approach; the green gray camouflage on Blue 16 is quite something! Not having an actual plane to study leads me in a lot of different directions! I am grateful for your posts, John!
Thanks for the comments! Since I've shown a peek of the P-38 undergoing the salt fading procedure, I may as well show the finished pictures. This is the 1/48 scale Academy P-38J kit. I threw quite a bit of aftermarket stuff at it including the Aires resin cockpit, Eduard resin wheels, Eduard turbocharger units and intakes, Eduard photoetch set, Master brass gun barrels and decals by Cutting Edge Decals.
That's a very nice P-38. I heard a lot of horror stories about the Academy kit. Warped fuselage parts, bad overall fit, sink marks etc.
What are your experiences?
Return to “Member's Gallery”
