Bolleken's 1:72 stuff
Re: Bolleken's 1:72 stuff
Bolleken wrote:Thanks Bruce,
If you look into that thread in another board, you will see all the work I put into the Hughes.
https://www.flugzeugforum.de/threads/hu ... -72.33041/
To see any pictures I guess you need to create an account. If you like anything, hit the "danke" button. You can store also answers in English. No issue. There you can also see how I drew the 3D model of the intakes and front wheel and the 3D-printing result.
Once I processing it further I am going to open a new thread here.
When I finished the 3 Mustangs, the XF-11 will be the next one
COOL.
I joined up.
Hitting like button every time you post.
A lot of work went into your XF-11, as you wrote above.
I know this is yet another photo of the model created for the movie, but what is this?
I am excited to see the result of this research and creation you are doing with the P-51s (I know you wrote that you would not have time to try a white primer, so what did you use?) and the XF-11. I will read and catch up on the progress overall, Marius. 'Tis a pity that I do not read German. I am using google to translate:
German:
Nun also lieber weiter am Innenausbau. Dazu folgendes Bild, das in der Bugnase eine durchbrochene Spante zeigt. Diese Spante existiert im Bausatz nicht und so versuchte ich einen Eigenbau.
English:
Now, therefore, go further inside the interior. This is the following picture, which shows a broken edge in the nose of the nose. These frames do not exist in the kit and so I tried to build my own.
I am not sure how to reply—if my reply goes to the very end of the thread or not—but I must tell you that your cockpit assembly is gorgeous! Really, Marius.
Exquisite work.
:shoutout:
Bolleken
Post by Bolleken »
Thank you Bruce dir joining and visiting. If you See also interested in my third Mustang from that Korea War Competition, you will find it in corresponding section.
https://www.flugzeugforum.de/threads/w2 ... -72.86669/
Also this board has a lot of my finished models stored.
For the XF-11 you right about the nose section. My interpretation of a different photo was wrong.
And all the best for your Horten. I am still following and learned a lot.
Bolleken
Post by Bolleken »
To reply you can use the answer field at the bottom of each page or you can use "zitieren" which means quote. Your answer will pop up at the very end.
Bolleken wrote:To reply you can use the answer field at the bottom of each page or you can use "zitieren" which means quote. Your answer will pop up at the very end.
Marius, I forgot to mention that it is possible to select English for the preference language on the board, which makes following and responding easy. What slows me down is the "container" that must be opened to see the image at the limited resolution of the site. It looks like images are uploaded to the forum servers, which may dictate the file size. Is that the case? Apologies for my impatience, I will follow all of your builds there, that's for sure.
The above is not critique, just a note about my own unfamiliarity with forum design. I am a member of the RPF and the Eagle Transporter forums which have similar set ups. I think I am noting my own reaction because I want to see all of your progress and catch up!!! Lol.
The cockpit work is outstanding, and I enjoyed the trials of designing a new wheel for the nose gear very much. I really like the historical records you use to inform your decisions!
I apologize for writing so much in English, but I cannot thank you enough for your assistance on the Horten. You gave me the best advice to stop worrying about the panel lines and fuel fillers, and instead see the shape as my primary target! Thank you so much for giving me great advice! That is why a friendly forum works best. I understand that being pressured to do your best is important, but having advice presented in a positive way is better. At least it is better for me. And I thank you.
Bolleken
Post by Bolleken »
Bruce, they lately switched the board software. Old threads were implemented, but attached pictures were switched into preview mode and not into full-screen. For new attachments I chose full-screen.
I really like that my comments on your Horten let you change your focus a bit.
And you can believe me that the Hughes is really a challenge. Thanks for the likes so far.
Bolleken
Post by Bolleken »
Today I applied a second Vallejo Metal Color, Chrome, to several areas onto the Hobbyboss Mustang. Masking and removal of masks, which were directly applied on the first layer, was easy. Currently I can recomend those Vallejos!
Wings going to be colored with Revell silver or Humbrol.
That looks great, Marius. The difference between the metallic finishes is exquisitely done!
Bolleken
Post by Bolleken »
Hi Bruce, did you review some more pages of the XF-11
thread?
Beside that here is the progress I made in the Hobbyboss Mustang.
Hey Marius, your XF-11 thread is one to savor, I have been working on the 1/72 Aoshima version of the Ta 152 H-1, not a lot of modeling work compared to what you are doing, my friend. You are making great progress on your Hobby Boss kit, the salt method keeps getting improved, that's for sure, particularly around the cockpit and wings, the effects look convincing at 1/72 scale, the particle clumps look right, great way to create wear and tear, a nice used look, to the fuselage.... I look forward to more.
