Scruffy's GAABSA Builds
Thomas_M
Re: Scruffy's GAABSA Builds
Post by Thomas_M »
Nearly missed this one... Wow, these Bandai kits seem to offer loads of detail! Much better than anything I have seen so far!
What a roomy cockpit! Your last pic really shows the detail pop out!
Scruffy
Post by Scruffy »
Well, the summer has been busy but this has not been forgotten; have gotten the major assemblies together...
While it does not show up well in these photos, the solar panels were sprayed a mottled black over dark grey and then several layers of Tamyia Clear Blue was sprayed on so when the light hits them they do have a blueish tone.
I had originally used the black decal framing for the nose glass, but as I suspected it just didn't look right, so today before leaving for the Pleasure Dome....er, ah em yeah.....work that is, I removed the decal and masked off the clear piece with Bare Metal Foil and sprayed it and the display stand black. When I get home tonight it should all be dry and I can put it all together. If I feel ambitious I might go ahead and spray the base as well to get this one all finished up. Either way I should get this one all wrapped up by the weekend.
Good to see the progress on this!
Great work Scruffy! :beau:
Scruffy
Post by Scruffy »
BorgR3mc0 wrote:Great work Scruffy! :beau:
Thank you!
Got the clear nose glazing unmasked and polished up after work and installed.
Now just have to put the sub-assemblies together and start painting the base.
Scruffy
Post by Scruffy »
The Tie itself is finished, took care of the last little bits this morning.....
Also started working on the base that came with the kit, just trying to make it a bit more interesting. That should be done in a couple of days.
Sweet!
Scruffy
Post by Scruffy »
Thank you, much appreciated!
Thanks for sharing! I might suggest some photos of this build against a plain background... poster board or a solid color bed sheet to remove the distractions from your fine build! That looks really sharp and needs to be shown off!
Scruffy
Post by Scruffy »
Yes, hopefully this will be done this weekend, and I will set up a small photo area and take some decent photos of the finished model. These are just taken as I go so to speak, while I'm working on it.
Return to “Go Ahead You Styreniac, Build Something...Already”
