IMC 1/32 Bell Jet Ranger - lylew
Member created Group Builds
Well, at least they included the empty sprues.....
Must be a vintage kit, too. The nstructions are printed on parchment1 :giggles:
As are the decals.
Then there is the plethora of loose parts. I have no idea if they are all present or not.
and, as advertised on the box - even has chrome parts. Guess I'll get to try the brake fluid removal method.
Re: IMC 1/32 Bell Jet Ranger - lylew
Chrome removal tip:
Try bleach. Worked in five minutes on 1964 chromed plastic, Lyle. Easy peasy and no harsh chemical spills to clean up at all.
Thomas_M
Post by Thomas_M »
Wow! Good ole plastic! For sure this one will be a rare sight when build!
Thomas_M
Post by Thomas_M »
Get the decals a good brush coat with MicroScale´s Liquid Decal Film to prevent those oldies from cracking when in the water. You also could try the old trick to pin the decals to a window (inside!) that gets lots of sunlight. Maybe they will improve their clarity.
I have never, repeat, never had good results with that stuff. Ever. Nada, Zip. No matter how many coats I brush on, They still crack. I may be able to print some, though.
speedgraflex wrote:Chrome removal tip:
Worked in about 30 seconds.....almost magic.
before:
after:
Clean as a whistle, Lyle! Absolutely perfect! I found this link—a good source of decal restoration ideas—but there are new Army helicopter decals available in 1/35. Maybe take a look at some of the newer tools of this particular kit for a builder type too?
Restoring old decals -
http://www.oldmodelkits.com/blog/plasit ... ld-decals/
Dry Transfers -
http://www.archertransfers.com/
Some more good stuff, Bruce! I can scan the decals, replace the yellow color with white and try that. First, I'll scan them - learned that lesson early.
Good luck, Lyle! I hope the links were useful... and I am curious to see what will happen next with this project!
Me, too! The kit has actually made it downstairs, so that is a start.
