A hind in 72 scale from Zvezda
Re: A hind in 72 scale from Zvezda
I’ve always loved the bad ass look of the Hind.
That Zvesda kit is light years ahead of the Hasegawa. Looks very good!
If I’m not mistaken, the Zvezda kit is recent (and obviously Russian in origin), while the Hasegawa kit is from the height of the Cold War in the 80’s when Soviet hardware was cloaked in mystery... even the stuff we had our hands on already!
- dmminiatures
- Master Member
Good to know! Never did helicopters and I might grab one if I see it.
Stikpusher wrote:If I’m not mistaken, the Zvezda kit is recent (and obviously Russian in origin), while the Hasegawa kit is from the height of the Cold War in the 80’s when Soviet hardware was cloaked in mystery... even the stuff we had our hands on already!
Monty / dmminiatures
I remember the first flanker from revell in late '80.. was little more than a toy
Two days of hard work on the hind
Seat belts added and seat and various sticks glued in place. Also clear glossy on instruments that needed to do.
Painted engines with metal brush, holed smaller exhausts and glued the two main inner assemplies
Gunner visor details, holed the mask part wheres eyes goes to see
not yet glued
Today works:
Glued main rotor parts
After cleaning all contact surfaces (removed paint mainly) and glued fout windows i glued the fuselages. Basically all works good except for a long triangle under belly. Also wings on
At the next
Today works:
At the next
Oh, that is a nasty gap! Maybe you can use styrene sot make a shim?
That belly was a tricky fit. My examples looked about the same...I applied some brute force, along with a little wiggle and *SNAP*...nothing broke, but the gap narrowed to a point of almost being a decent fit. The biggest problem I had was the parts surrounding the engines. One was worse than the other, but both kits gave me a little trouble.
Probably this A version of the mold works better on engine zones and .. black hole under belly . I friend of mone have the mi-35 version, i'm curious to know if theres another variant of the gapFermis wrote:That belly was a tricky fit. My examples looked about the same...I applied some brute force, along with a little wiggle and *SNAP*...nothing broke, but the gap narrowed to a point of almost being a decent fit. The biggest problem I had was the parts surrounding the engines. One was worse than the other, but both kits gave me a little trouble.
Ps
For the remaning i glued the assembly withouth clips , just lemon tamiya general glue and green cap to glue the hardest zones.
My only real disappointing on this kit is the requirement to use the engines if you don't want to open all the upper doors
