1:48 Tamiya Corsair
Re: 1:48 Tamiya Corsair
Great work on the Corsair! If the engine's not glued into the cowling, I'd recommend wiring it since there is a good view into the engine.
Me too. I keep dancing around the idea based on what you wrote about getting too wrapped up in this... but I feel you could take a pin vise (you have one, I assume) and make a few holes (the visible five on each side of the silver "horseshoe" of the wiring harness. I hear Carlos approaching... hang on, let me look up this part—"automatic spark advance tubing" (fingers crossed). Put the holes in and add the salient features of a wiring harness that are visible yourself.
Yeah, I know I said I wasn’t ... but dammit it looks really good and a wiring harness would be a fantastic capper! And I’ve got time too! All the time in the world, baby. So, like my second cousin Chad X of Delta Sigma Chi always says: “Fuck yeah bro!”
It’s on. I have s tee tiny drill, and a kickass reference photo thanks to Bruce, and literally a metric ton of derelict coaxial cable which is chock-full of wires that should look relatively scale appropriate.
Awesome!!
Awesome!!
Chad X knows wisdom, my friend. I would cover that beautiful paint werk before doing any procedures. That’s for sure!
Already done, my man! Took yours and Carlos’ advice and covered it with a nice coat of Tamiya Clear. So we’re good there.
Njammie !KennyX wrote:First thing’s first though, this was a good time to break out my Tamiya weathering kit. Not too bad. These’ll look nice under the open cowl flaps:
Looking forward to the wiring, a task I have never got into... yet.... :-)
It shouldn't be too difficult since the molded wiring harness is quite thick and should be able to accommodate drilled holes. Lots of reference pics for the Pratt & Whitney R-2800 engine on the net...
I don’t have a drill bit for my little drill small enough.
I tried two different ways- gluing the wires to the ring, and gluing them to the back of it for a better hold. Neither worked well. Spent the weekend on it. Determined that for this scale, on an engine that I’ve already painted and clear coated, this is a huge pain in the ass and not worth the effort.
I’m going to take a break, give it a day to cool off, and decide to either go with my original plan and worry about doing it on my Hellcat while I build the engine, or try again on this model.
Good afternoon, as soon as I read “pain in the ass,” I thought, “Don’t do it, not if it is going to make you feel badly towards what you are doing with details.”
Although I saw the photo, and thought, “Right on!”
Without the drill bit size, though... it’s tough to support proceeding. I did think about this as a “Challenge Round” for you, so it is heartening to see you make the attempts. Sincerely. A major element of a good build log like yours is documenting all of the stops, starts, U-Turns and dead ends along the way. I find a lot of comfort in reading builds where a modeler lets it all hang out, and puts integrity out there.
Externally, we know Eduard has a PE harness. I would pull a photo of it and simplify the hell out of it—half a donut hidden behind the existing piece with the wires already attached would be my firing solution... I will sketch this after chow.
