Revell '41 Willys "Demon II"-Under Glass-09/07
Re: Revell '41 Willys "Demon II"-Progress on the Hemi-06/16
Beautiful work Joe! She's almost ready to start up!
Outstanding work Joe !!
What a joy to see this beautiful car model evolving!
Re: Revell '41 Willys "Demon II" Chassis Complete-06/12
mustang1989 wrote:
The “wow” factor on your update photos is off the chart here! :shoutout:
:P1: I gotta agree with Carlos here 100%!
Thanks guys.
I've been on this one for the last three days and had to switch over to stance adjustments and body prep for a bit due to complications with the fuel delivery system. Still in the fuel line routing and install phase and it's not the easiest thing to pull off. I knew it'd be like that too which is why I put it off for as long as I did. Hoping to get over this "hump" so I can continue onwards in a halfway timely fashion. I did tone the brightness on the plug wires down a bit as they were to "plastic" looking and too bright. Will post updates when I get a little more done.
Best wishes, Joe! I look forward to your latest installments!
Thanks Bruce. I've still got a little tweaking to do and one throttle return spring to install on the rear carburetor but here's the fruits of today's labor:
Re: Revell '41 Willys "Demon II"-Progress 07/02
Joe—looks superb! That is without a doubt the cleanest and the clean assembly work ever!
speedgraflex wrote:Joe—looks superb! That is without a doubt the cleanest and the clean assembly work ever!
Thanks Bruce. I've got some tidying up to do with that fuel line up front though. Will see about re-doing that one.
