My clip was from the Sam Fuller film, The Big Red One. It’s a scene that happens at an insane asylum in Belgium. It’s a very surrealistic scene at times.
The Searchers is one I need to watch.
Re: Hasegawa 1/32 N.A. P-51D "Cripes A' Mighty" IV SN 44-149
I remember watching a documentary on Sam Fuller. He was being interviewed by Quentin Tarentino. QT talked about how he was affected by Mark Hamill—Luke Skywalker—staring at the remains in a crematorium. I still need to watch the movie.Stikpusher wrote:My clip was from the Sam Fuller film, The Big Red One. It’s a scene that happens at an insane asylum in Belgium. It’s a very surrealistic scene at times.
My favorite Sam Fuller films are "Crimson Kimono" and "Forty Guns."
Really? Need to watch it as well!Stikpusher wrote:My clip was from the Sam Fuller film, The Big Red One. It’s a scene that happens at an insane asylum in Belgium. It’s a very surrealistic scene at times.
Beautiful!
Carlos, thank you so much, sincerely! Thank you for following, giving great advice and encouragement! You are an ace!
Bravo!!
BlackSheep214, thank you so much and most sincerely! Thank you for following along and your support. I am looking forward to your P-51D build when you are ready to begin, and I am following your current work as well.
This was a tough morning. I needed to find ways to sand the stand's rough areas and remove the bonding glue from the joins as much as possible, then work out how to support the aircraft inside the wing with the caveat emperor being the amount of depth before the cockpit floor begins being one issue. I designed a rectangular tile of the same walnut as the base to fit tightly inside the wing then punched holes through the exterior of the wing straight up, then at an angle in the area between the wheel wells. I also had to take down a small amount of a central rib to make the connection less topsy-turvy.
That is a very nice stand Bruce! It is also cool that you built that as well as the model. I think it adds so much to have a nice presentation of the finished build. Especially when the builder takes the time and effort to come up with an idea and then execute it with the same degree of craftmanship evidenced in the piece it is supporting.
